Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: JZX32 Toronto Canada
    Aug 2010
    Toronto
    61
    Here are some pics of my car
    2jz VVTi and 5 speed swap, front coilovers, camber plates, Audi TT front seats, all new bushings, 4 links,
    secret one of a kind bumper swap to rid myself of the scourge of the hideous park benches that molest every North American x3 :lol:
    everything supension steering new
    Love driving it....x3 FTW
    .... some decent photos
    Uploaded with ImageShack.us
    May 2012
    COSTA RICA, CENTRAL AMERICA.
    192
    Re: JZX32 Toronto Canada
    wow! nice looking cressida :tu: :tu: :shock: :twisted:
    Apr 2011
    TX
    283
    daaaaaaaaaamn. did you build it yourself or buy it swapped? how about some details?
    Oct 2011
    Alberta
    171
    Looks damn fine. Super clean bumper swap. Love the work equips on these cars too.
    Jun 2009
    Lynnwood, Washington
    349
    Why super secret bumper treatment? Share with the community and let it grow!
    Good looking car, do you have engine bay shots?
    Love the white lettering on the tires gives it a "race" look.
    Aug 2010
    Toronto
    61
    I swapped it myself, here are some basic details, I will answer any specific questions that anyone has, the hardest part was the wiring
    - I used a JDM vvti engine.....these have no immobilzer, if you can't source a JDM one, better stay with an older 2jzge
    - I had to join a Japanese auction website and imported a JDM ECU as the ecu I got with my engine was a North American one (bastards at engine place....but I was a newbie when this process started and didn't know it was wrong ecu)
    - wiring diagrams for JDM 2jzge vvti are only in Thai, located here: http://gallery2.plebeians.net/v/cars/su ... -i_1_.jpg/
    had to study these for awhile, and look up all abbreviations etc. to make sure what was what
    - engine mounts from excessive will work (x7 jz mounts) as the block from any m series engine is the same
    - I used ones for a jz mk3 swap that I got off of ebay before I knew of the excessive mounts, and had to buy two sets because the mounts weren't symmetrical, then I cut and welded them at an angle to sit the engine 2" farther back. With the excessive mounts you can avoid all that
    ...to be continued
    Jun 2009
    349
    so nice and clean under the hood. :tu:
    Jul 2010
    Jackson TN
    151
    and the bumper?
    Jan 2010
    Fort Eustis, VA
    71
    Mr. Clean, What radiator is that?
    Aug 2010
    Toronto
    61
    Rad is a universal Mishimoto one with the inlet(top) on the drivers side and outlet(bottom) on passenger
    Everyone knows JDM spec bumpers are impossible to get.....so I just looked at what was available, old american car bumpers from the 60s that had the shapes I was looking for. I just cut and shortened them and welded the brackets.....easy.
    I used a w58 from an mk2, and with the engine as far back in the bay as I could get it (valve cover like 1/2" from firewall)...the trans bolted up using stock trans cross member, and shifter in stock hole. Lucky.
    Luckily, the JDM 2jz uses a return line on the fuel rail, so I just ran new braided fuel line to an aeromotive stealth fuel cell w pump inside and mounted that in the trunk after taking out the old tank. I didn't want to deal with keeping the non baffled old tank at least a 1/4" full, or redoing the stock tanks sending unit with new lines for high psi EFI....too much hassel.
    Xerd/Mazzurri header that was custom fit because the collector was interfering with the idler arm so I cut and rewelded it so it angles closer to the engine/trans.
    T3 camber plates and weld-on coilovers, .....eibach circle track race springs in the rear (350lbs was the lowest stiffnes they came in). Camaro AGX short stroke in the rear and MR2 short stroke in the front shortened struts.
    Added a clutch pedal from an is300....gas pedal from an MR2, and had to find an extra long throttle cable used in some ae86s in order to reach the JDM throttle linkage as its on the passenger side....
    Did an AC delete....powersteering is hooked up.....6 componeant speaker and 2 amps with sub and kenwood iphone deck...sounds nice
    Thats all I can think of for now....like I said, any specific questions you have I can try and answer with more details.....thanks for all the positive comments.
    Another good guy to ask about this swap is Lloyd...aka Zombie Cressida...although he got a vvti from a friend and was able to get around immobilizer because he also got the steering column transponder as well to make it run....
    Like I said before...interms of ease, the earlier 2jz is much easier wiring swap....although the vvti is nice and torquy !!
  1. Jzx32 FOR SALE
    By clark_griswold in forum Toyota Swap Meet
    Last Post: 11-27-2013, 10:01 AM
  2. Hello from Toronto! 280z owner
    By miky360 in forum Introduce Yourself
    Last Post: 08-07-2013, 07:07 PM
  3. FS: FJ20E Engine & Trans Complete Swap Toronto Canada
    By Heatw in forum Datsun/Nissan Swap Meet
    Last Post: 07-04-2013, 05:18 AM
  4. Sparkle Garage 1979 jzx32 shakotan zombie
    By toji004 in forum Toyota Garage
    Last Post: 06-18-2013, 05:53 AM
  5. 1982 Dr30 In Toronto Canada
    By Heatw in forum Introduce Yourself
    Last Post: 10-04-2012, 02:31 AM
