Results 1 to 4 of 4
Thread: Diff / axle info needed.
    Jul 2012
    439
    I have a 1976 corolla with a 2 pinion, 6.38" diff. 4:10 ratio (stock). I want to know if a 1981 4 pinion, 6.38" diff with a 3:583 ratio will fit.
    Are the axle shaft splines the same?
    Aug 2012
    Montreal, Canada
    111
    Re: Diff / axle info needed.
    All 8 bolt S type 6.38 use the same axle spline number and dia. It'll bolt on like stock no problem... only question I have is why? Why go from a nice 4.1 to a sloppy 3.58?
    Jul 2012
    439
    Currently I have a A40 auto in the place that my t50 will eventually fit. Freeway speeds on 185/60r14's revs a bit high for my liking. After I get the 5 speed in ill probably go back to the low ratio or something in between. Thanks for the info.
    Jan 2009
    Mauka
    66
    Pumpkin will fit but driveshaft flange may differ. Bolt up kitty corner with only two bolts (I have seen people race with slicks with only two bolts) or you can drill the other two holes. I drill my pumpkin flange with the driveshaft on and never had any problems. You might be lucky and it will match, I forget the year that it changed over.
  1. 1977 sports coupe rear axle ratio options info needed
    By heavyrolla in forum Toyota Garage
    Last Post: 04-15-2015, 04:10 AM
  2. 7MGE Wiring Info Needed??(pics.)
    Last Post: 10-28-2012, 06:30 PM
  3. R200 diff. CLSD with axle's
    By in forum Datsun/Nissan Swap Meet
    Last Post: 09-06-2012, 04:42 AM
  4. Datsun trucks info needed!
    By Eric in forum Datsun/Nissan Garage
    Last Post: 10-31-2011, 11:19 PM
  5. MS65 Crown suspension info needed...
    By Denver in forum Toyota Garage
    Last Post: 10-07-2010, 11:59 AM
