Results 1 to 3 of 3
Thread: Rear pinion seal
    Jun 2008
    ohio us
    Rear pinion seal
    Is it hard to change the rear pinion seal on a 1983 corolla lift back? my is leaking or is this something professional should do ?I really want to learn how too do it rather than pay someone to do it could someone give me a step by step how to do it? Thanks
    May 2012
    Re: Rear pinion seal
    It's not that difficult--in theory. Four bolts to drop the driveshaft, and one big ass nut that holds the pinion flange on, slide off pinion flange, pry off old seal. Install is basically reverse of removal. The tricky parts are:
    1) Do you have/can you get a socket for that nut (I forget the exact size, but it is something like 24 or 27MM)
    2) Getting the new seal back on without damaging it. If you have changed a seal before, chances are that the shaft you are sealing was not installed at the time (i.e. you remove the axle to change the axle seal, or you remove the hub from the spindle to change the wheel bearing seal). On a diff the pinion shaft is still there, which makes seal installation more difficult.
    3) Here is the trickiest part: The procedure for tightening that big ass nut is not to a torque spec, but a preload value. Basically you tighten it until you get a certain amount of resistance when turning it. Too loose or too tight could destroy your diff after a while. What I did on mine several years ago (because I had no way to measure the preload at the time) was to just keep tightening a little at a time (like 1/8 of a turn) until I got a slight increase in drag when turning it. After driving it a bit it got noisy, so I went back under the car and found it was spinning too easily, so I tightened it a little more. After that , it worked fine for years. I just took this diff out last weekend and it still looks great after about 75,000 miles.
    I would say you could do it IF you are relatively mechanically inclined, have changed some kind of seal before, AND are open to the possibility of damaging this diff (like you can get another one at a pick a part if you mess this one up). Otherwise have someone do it.
    I hope this helps.
    Jul 2012
    Wow. Nice write up with tips. I may be doing this as well. The only thing I can add is: You can take out the carrier / diff and bring it to a shop to save some $$$ rather than having them pull it all out. You can learn about your car while saving $$$.
  1. Rear window seal options
    By UtahSleeper in forum Resto Tips, Wheels & Other Goodies
    Last Post: 10-28-2013, 06:58 PM
  2. R100 rear window, seal, trim- complete.
    By CamanoRx2 in forum Mazda Swap Meet
    Last Post: 07-21-2012, 12:51 AM
  3. TE72 hardtop brand new rear glass seal
    By 3tcRob in forum Toyota Swap Meet
    Last Post: 07-04-2012, 02:39 AM
  4. Where to find rear window seal?
    By UtahSleeper in forum Toyota Garage
    Last Post: 03-19-2012, 06:44 PM
