Results 1 to 8 of 8
Thread: Interchangeable parts for my '79 glc wagon
    Jun 2013
    Southern California
    9
    Hey all, I'm the 2nd owner of a great little car, the 323
    given as how I haven't seen very many of these around
    southern cali, let alone at a junk yard, I don't have many
    options if I need a quick fix...
    so my question: are there other cars that have parts I can grab from?
    Right now I want to lower it a bit or just fix up the suspension and switch
    the rear brakes to discs for better stopping power.
    any help would be awesome, thanks
    Jun 2013
    Southern California
    9
    Re: Interchangeable parts for my '79 glc wagon
    I haven't been on in a while and saw the notice about the forum crash.... did I miss any posts on here?
    (bump)
    Jun 2009
    Melbourne, Australia
    802
    yes you did actually.
    I said go and check out ausrotary.
    (GLC/323 and RX-3/808 have interchangeable bits)
    Sep 2013
    21
    I had posted on here too but it is gone now. For suspension and brakes you can use a lot of the first gen rx7 stuff. The front suspension is a bolt in affair, but I suggest using coil overs and camber plates to get things right. Up top you can either drill new holes or use the 323/glc strut mount with a bearing. You wagon has leafs in the rear so leaf spring lowering is accomplished just like any other car with leaf springs. Rear shocks are actually still available for your application as well. Check Rock Auto and Ebay for oem items like bushings and voltage regulators etc.
    Jun 2013
    Southern California
    9
    thanks for the tip. I wasn't aware that the RX-3 would work too
    Jun 2013
    Southern California
    9
    Quote Originally Posted by cfamilyfix
    thanks for the info. The RX-7 struts are lower than the stock glc ones right? I've seen a few sites that sell one or two types of front coilovers for the 7. I'm going to have a go with that soon
    Jul 2011
    24
    I'm getting ready to swap my 1982 GLC wagons front suspension with a coilover set-up from a 1981 rx7. I would read the tech articles from the AusRotary website as recommended in a previous post. The thread pitch on Mazda brake lines changed in 1981/82 (outlined in the tech articles) and of course they're different on my two set-ups. The GLC is really just a universal parts bin of whatever they had..... Lots of pieces interchange with earlier rx3/808 cars. These cars are getting really hard to find these days..... most went to the crusher.
    Sep 2013
    21
    Yes rx7 front suspension does lower a glc significantly...and introduces quite a bit of positive camber. You will want to dial that out with adjustable strut tops or camber plates. The real benefit is the brakes.
  1. Skyline C210 Center link/ Cross rod parts & interchangeable
    By sukh in forum Datsun/Nissan Garage
    Last Post: 03-22-2013, 07:01 PM
  2. ae92 parts(wagon)
    By the_bus_driver in forum Toyota Swap Meet
    Last Post: 12-08-2012, 02:42 AM
  3. help with chasis codes and interchangeable parts
    By chowdig in forum Toyota Garage
    Last Post: 07-28-2010, 04:57 AM
  4. W NOS 323 Wagon parts
    By crankshaft in forum Mazda Swap Meet
    Last Post: 06-29-2010, 10:07 AM
  5. WTB: 510 Wagon parts.....
    By botoneta in forum Datsun/Nissan Swap Meet
    Last Post: 02-17-2010, 11:49 AM
