Results 1 to 3 of 3
Thread: 78 TE31 gas tank o-rings/seals
    Where can I get the orings for the gas tank?
    Looks like two are the same size (fuel sender and filler neck), and then
    the main gas feed/vent at the top is slightly smaller.
    Please don't say "go to a parts store". I actually work in auto parts and have searched high and low at my store, plus my competitors with no luck.
    Everything is either the wrong ID/OD (and ends up leaking, or breaking the O-ring from being stretched), or is too thick (cross section) so I can't get the lock ring in place.
    I found one that I *might* be able to make work for the gas feed at the top, but not the others.
    Does anybody know what the exact dimensions of these should be? ID/OD and cross section.
    Please advise guys! I know someone has replaced these things!
    Jun 2013
    Oakland, CA
    42
    Re: 78 TE31 gas tank o-rings/seals
    Try searching around on this site...
    http://www.toyotapartszone.com/Page_Pro ... 5=MTM;6=4F)&originCountry=(10=USA)&sectionID=&componentsID=7 7-01
    The original parts are non existent. I tried ordering them through a friend that works for Toyota before I made this post.
    I ordered a bunch of similar sizes online and tried them all. Found some that work.
    For future reference and searchability:
    http://Www.theoringstore.com
    #B70331 x 2 (please note you have to order at least 4, though, as the manufacturer has a minimum order on each number). This size works for the filler neck and the sender.
    #B70329 x 1 (again, you'll see a minimum but they're ridiculously cheap). This size works for the center/top feed/return line unit.
    Hope this helps someone in the future.
  1. FS: 4M Piston Rings OEM
    By hampaslupa in forum Toyota Swap Meet
    Last Post: 01-31-2012, 03:21 AM
  2. Trim Rings.
    By Celicaholic in forum Toyota Swap Meet
    Last Post: 12-16-2010, 06:38 PM
  3. Hand rings!
    By loumer in forum General Discussion, JNC News & FAQ
    Last Post: 11-11-2010, 03:51 AM
  4. WTB: Drag rings
    By DomoArigato in forum Wheels Swap Meet
    Last Post: 08-25-2010, 05:32 AM
  5. JDM subway rings
    By arsonist63086 in forum General Discussion, JNC News & FAQ
    Last Post: 11-05-2009, 07:23 AM
