Results 1 to 8 of 8
Thread: rebuilt aisan carb on my rt52 and need HELP!!
    May 2010
    SOuthern oregon
    34
    so... i rebuilt the aisan carb on my rt52 coupe and am having nothing but trouble getting it to run right. no matter how i adjust the float it just overfills the bowl. should i keep screwing with it or ditch it in favor of something else? any imput is greatly appreciated. the weather is nice now and im dying to cruise this thing
    May 2010
    SOuthern oregon
    34
    Re: rebuilt aisan carb on my rt52 and need HELP!!
    here is the corona in question
    Sep 2009
    Los Angeles
    161
    Sounds like the needle is not seating. Fuel pump pressure too high? Needle does not have the rubber cone or rubber cone is dried out? Floats not floating? Crud on the needle seat?
    May 2010
    SOuthern oregon
    34
    how do i adjust the fuel pressure? the needle and seat are new. and i inspected them for debris and it is clean as a whistle.
    Jul 2012
    439
    make sure your float doesnt have a tiny hole in it. fuel inside float = no float = always flooded.
    My rebuild sheet for my carb came with a specific way to adjust the float bowl. Did you get one of these, and did you follow it?
    May 2010
    SOuthern oregon
    34
    the float seemed fine but i will re-inspect it. my rebuild kit came wit a measuring card and instructions which i followed the best i know how.
    Check your accelerator pump nozzle it could be blocked.
  1. Aisan carb for late 70's 6cyl Toyotas?
    By Futures in forum Universal Parts Swap Meet
    Last Post: 07-10-2015, 01:34 AM
  2. Main jets for Aisan
    By Skellington in forum Toyota Garage
    Last Post: 09-28-2012, 06:28 PM
  3. SU / Aisan Twin Carbs, 18R - GONE
    By Kylehugo in forum Toyota Swap Meet
    Last Post: 03-05-2012, 03:12 AM
  4. DCOE Carb help? - Carb bogging down at acceleration
    By avianman in forum General Discussion, JNC News & FAQ
    Last Post: 04-09-2011, 06:53 PM
  5. Replies: 1
    Last Post: 07-04-2009, 07:10 AM
