Results 1 to 2 of 2
Thread: 17th Annual Spring Nationals, May 4th - 5th, ETown
    Sep 2007
    New Jersey
    123
    Facebook RSVP page: http://www.facebook.com/events/125730787598569/
    EVENT: 17th Annual Sport Compact Spring Nationals
    DATE: May 4th & 5th, 2013
    GATE TIMES: Saturday, May 4th – Gates Open 11 Am
    Sunday, May 5th – Gates Open 8 AM
    Heads Up & Index Qualifying:
    Saturday, May 4th – 3:00 PM to 8:00 PM
    Sunday, May 5th – 10:30 AM
    Eliminations: Sunday, May 5th – 2:00 PM
    Saturday, Top 50 Car Show
    Sunday, Fully Judged Car Show
    PRICES:
    Racer Prices:
    PRO RWD / Q16 Tech Card - $100 (2 Day)
    Heads Up / Index Class Tech Card - $80 (2 Day)
    Test and Tune Tech Card - $30 (Saturday Only)
    Bracket Tech Card - $55 (Sunday Only)
    Car Show Prices:
    Saturday, May 4th - Top 50 Show - $30.00
    Sunday, May 5th – Fully Judged Car Show - $45.00
    Spectator Prices:
    Saturday - $20.00
    Sunday - $25.00
    2 Day Spectator Pass - $35.00
    HEADS UP & INDEX RACING CLASSES:
    PRO RWD
    Open to all RWD 3/4 and full chassis sport compact vehicles
    Open to all 4 and 6 cylinder and rotary power plants
    Heads up, Pro tree, Pro ladder
    Maximum displacement:
    6 cylinders: 4.0L
    Maximum two power adders allowed
    Minimum weights:
    4 cylinder/2 rotor: 2000 lbs (over 3.0 liter add 200 lbs)
    3 rotor: 2200 lbs
    6 cyl: 2400 lbs
    *3/4 chassis- deduct 100 lbs
    *3/4 chassis must retain original firewall, OEM front shock towers and frame rails in front of the firewall. Front Struts must mount to as-built upper OEM location. Final strut installation must be in a manner such that removing the bolts on top of the strut tower allows strut assembly removal to be considered a 3/4 chassis.
    *Engine Containment Device Required
    16 Car Field. (Non-qualifiers may be provided the courtesy to run in Bracket 1 if time permits.)
    Must have 16 cars for full payout.
    Winner - $2,000 + Trophy
    Runner - Up - $1,000 + Trophy
    Semi's - $500 + Trophy
    1/4's - $250
    Sport FWD
    Open to all 4 and 6 cylinder Import/Sport Compact Cars. “SFWD Trim” Must have 2 front seats and Interior panels required. No rear seats OK. No Gutted out cars permitted. Max Tire 25 x 9.0? Open exhaust OK. Lexan prohibited. Water to Air intercoolers Prohibited 1 piece fronts prohibited. 3 piece fronts OK. 72mm Max Inducer Turbo size (Max 102mm Exd-billet, 105mm Exd-Cast. Up to 67mm-max exd 94mm). Up to 2 Power adders allowed(comb ok) Fuel Cell OK stock location or trunk area only – NHRA guidelines MUST be followed. .400 PT, Sportsman Ladder.
    $1000+ Trophy
    $500+ Trophy
    $250 + Trophy
    Full class rules and information for SFWD can be found here: http://www.facebook.com/notes/ortega-gl ... 5697494731
    Pro Stock
    NHRA Rules. Heads-Up Eliminator. .400 Pro Tree. Pro Ladder. FWD Only. (Complete rules available)
    Must have 8 cars for full payout.
    $1,000 + Trophy
    $500 + Trophy
    $250 + Trophy
    All Motor
    4 and 6 cylinder. FWD only. Naturally Aspirated. Lexan ok (front windshield MUST be glass). No 1 piece front ends (3 piece OK). 25? x 9.0? max slick. Fuel Cell OK – NHRA guidelines MUST be followed.. No pro level cars. Gutted interior ok. Open exhaust ok. Pro ladder. .400 PT. Heads-Up Eliminator. 16 car field. *Must have 16 cars for full payout. Min. Honda weights
    Honda: 2200lbs- J(all v6) series,
    2150lbs – K series, F2K,
    2000lbs – H series
    1900lbs – B series
    $800 + Trophy
    $400 + Trophy
    $200 + Trophy
    Full class rules and information for All Motor can be found here: http://www.facebook.com/notes/ortega-gl ... 6134161354
    10.50 Index
    Open to all Import/Sport Compact Cars.
    Any Combination allowed at any weight.
    No Throttle Stops or Delay Boxes allowed. No Sandbagging.
    NHRA safety rules apply. 32 Car Field
    .400 Pro Tree, No Deep Staging allowed, Sportsman Ladder.
    Non-Qualifiers will go into the faster bracket
    Must have 32 cars for full payout.
    $600 + Trophy
    $300 + Trophy
    $150 + Trophy
    11.50 Index
    .400 Pro Tree, No Deep Staging allowed, Sportsman Ladder. Non-Qualifiers will go into the faster bracket
    $600 + Trophy
    $300 + Trophy
    $150 + Trophy
    Qualifying on Saturday & Sunday with Heads Up & Index Classes – Eliminations Sunday after Qualifying.
    Class
    Quick 16*
    7.00 to 9.00:
    Open to AWD, RWD, FWD Hot Rod Pro FWD trim only.
    Rotary and 4, 6 cyl Import/Domestic sport compact motors ok, Import V8 power plants ok (ie. Toyota, Nissan).
    NHRA safety equipment required.
    No year limitation on full tube chassis or back half.
    .500 Full Tree, Bracket Style Eliminator.
    $2,000 + Trophy
    $1,000 + Trophy
    $500 + Trophy
    Bracket Classes – Sunday, May 5th
    Bracket 1
    10.99 seconds & Quicker - All Run, .500 Full Tree, Bracket Style Eliminator.
    $800 + Trophy
    $400 + Trophy
    $100 + Trophy
    Bracket 2
    11.00 to 14.99 - All Run, .500 Full Tree, Bracket Style Eliminator.
    $600 + Trophy
    $300 + Trophy
    $100 + Trophy
    Bracket 3
    15.00 and Slower - All Run, .500 Full Tree, Bracket Style Eliminator.
    $400 + Trophy
    $200 + Trophy
    $50 + Trophy
    All event class information with the exception to SFWD and All Motor can be found here: http://www.facebook.com/notes/ortega-gl ... 4340828200
    Car Show Information:
    Sunday, May 5th – Fully Judged Car Show.
    Registration closes, Sunday 1:00 pm - SHARP
    Car Show Specialty Awards:
    Best of Show - $1,000 & Trophy
    Best Team Award* - $500 & Trophy
    (*Must have 10 or more members to enter)
    Best Euro - $200 & Trophy
    Best JDM - $200 & Trophy
    Best Domestic - $200 & Trophy
    Best VIP - $200
    Car Show Classes
    1 Honda Civic – 2 door 92 to 95
    2 Honda Civic – 2 door 96 to 05
    3 Honda Civic – 2 & 4 door 06 & newer
    4 Honda Civic – 4 door
    5 Honda Civic 91 and Older
    6 Honda Other
    7 Honda Accord
    8 Honda Prelude
    9 Honda S2000
    10 Acura Sedan
    11 Acura (exc. Integra & RSX)
    12 Acura Integra/RSX
    13 Mazda
    14 Mazda RX7 / RX8
    15 Toyota
    16 Toyota Supra
    17 Nissan Skyline GTR
    18 Nissan
    19 Lexus
    20 Infiniti
    21 VW – 2 door
    22 VW – 4 door
    23 Luxury Asian
    24 Luxury European
    25 Mitsubishi
    26 EVO
    27 Eclipse, Talon & Laser
    28 Porsche
    29 BMW M Edition
    30 BMW- 2 door
    31 BMW – 4 door
    32 Subaru
    33 Subaru STI
    34 Audi – 2 door
    35 Audi – 4 door
    36 Lamborghini
    37 Mercedes Benz – 2 door
    38 Mercedes Benz – 4 door
    39 VIP
    40 Ford
    41 Mustang
    42 Dodge/Chrysler
    43 Neon
    44 American Sport Compact
    45 Domestic Midsize
    46 Domestic Fullsize
    47 Classic
    48 Hyundai
    35 Import Other
    36 SCION xA
    37 SCION xB
    38 Scion tC
    39 Radical Mild
    40 Radical Wild
    Truck Show Classes
    41 Mini SUV Stock (Imp/Dom)
    42 Mini SUV Mod. (Imp/Dom)
    43 Mid/Full Size Stock SUV
    44 Mid/Full Size Mod. SUV
    45 Sport Truck Stock (Imp/Dom)
    46 Sport Truck Mod (Imp/Dom)
    47 Mid/Full Size Truck Stock (Imp/Dom)
    48 Mid/Full Size Truck Mod (Imp/Dom)
    49 Radical Trucks/SUV (Imp/Dom)
    Bike Show Classes
    50 Bicycles/ Trike
    51 Radical Bicycles/ Trike
    52 Motorcycles
    53 Radical Motorcycles
    54 Mini Bike
    Sep 2007
    New Jersey
    123
    Re: 17th Annual Spring Nationals, May 4th - 5th, ETown
    Bump for this weekend!
  1. May 17th 5th Annual Cruise to the Bridge of the Gods
    By yella81celica in forum Events, Meets & Gatherings
    Last Post: 04-25-2015, 06:23 PM
  2. 17th Annual Summer Slam pics
    By tomstwincam in forum Events, Meets & Gatherings
    Last Post: 07-04-2012, 07:07 PM
  3. Spring Nationals 4/28 - 4/29, Englishtown
    Last Post: 04-30-2012, 11:50 PM
  4. 17th Annual Pan Americans, June 15th-17th, Atco Raceway
    Last Post: 06-28-2011, 09:13 PM
  5. Spring Nationals 4/30-5/1, englishtown,NJ
    Last Post: 05-03-2011, 01:04 AM
