Results 1 to 6 of 6
Thread: Reattach hood skin
    Sep 2010
    Magna, UT
    689
    Reattach hood skin
    So, the hood skin/metal on my corolla isn't completely glued to the hood frame anymore and I would like to know what are some recomendations people have for fixing this.
    Thanks
    Apr 2009
    Portland OR
    9
    Re: Reattach hood skin
    The glue spots are I believe to prevent vibrations through the skin and stiffen it up by tying the center to the frame. On my (and practically everyone ele's) 1st gen celica deck lid, every one of those spots corresponded to a rotting hole through the skin. Be sure what you use is closed cell so it doesn't hold moisture (shame on you Toyota). At the restoration shop I used to work for, there was concern about the glue spots holding down that area during heat expansion and causing divets which would show through the paint (mega-dollar show car where this would matter). On a few occasions, we used automotive urethane windshield sealant in the correct spots after removing to old stuff, allowed it to fully cure, then sliced through each spot to give it an unrestricted rest point. One which wouldn't prevent the skin from expanding in the sun and causing dimples. If you do go this route, give the urethane ample time to cure as it is the messiest stuff known to man.
    May 2010
    St. Marys Ga
    79
    You are talking about those little hard like foam spots?
    Just ignore the horrible under coating around there. If it is falling apart there it is doing the same in the trunk lid and the roof bows and other places. I think after doing a little bit of research that I think that it is. It is a foam from 3m but any nvh foam like it should work. Don't use seam sealer or urethane windshield as it will cause dimples.
    http://3mcollision.com/products/sound-d ... 04274.html
    http://multimedia.3m.com/mws/mediawebse ... 6E666666--
    Sep 2010
    Magna, UT
    689
    Thats what I am talking about. Have to give that stuff a try. Thanks.
    May 2010
    St. Marys Ga
    79
    I talked with a service rep and was told that nvh would work as an anti-flutter materiel, but they did not know if it had adhesive strength to pull the frame upward. I hope that the gap is just from it drying out/ rotting out. Also check the bows the support the roof and anywhere else that might use this. This stuff is good to use if you have trunk rattle from a big bass system. The only thing is it is not cheap, and is around 80$ is the cheapest I could find. Most of that cost is for the gun to apply the product. I would see If a local body shop has a gun you can use.
    Note: 3m sells two kinds of this foam I don't know and could not get an answer if 1 was better then the other or was stronger.
    http://3mcollision.com/3m-flexible-foam-08463.html
    I been searching all day and found 20 different answers but the over whelming thing was don't use panel adhesive or urethane glues. The foam has the proper flex and wont ripple the sheet metal. I'm not sure if it is strong enough to pull a sagging frame up or pull a bowing hood skin down. I do know it is used on the door panels on my Saturn to prevent rattles from the plastic skins and it stuck them on pretty good.
    May 2010
    St. Marys Ga
    79
    Ok yes I have found that this is indeed the proper stuff to use.
    http://www.mazdas247.com/forum/showthre ... ost6144103
    if you want to do it yourself, you can order the same material they called out in TSB from bodyshops, or ebay or other internet means. I thinking about doing it so I don't have to bring it in and wait 6 hours for it to dry at the dealer, 3M-34274 (4274 is the one in the TSB) is the smaller bottle, I have the 2 part mixer dispenser at work so I'm going to do it myself.
  1. wtb rx2 hood in california
    By mattallac in forum Mazda Swap Meet
    Last Post: 06-20-2012, 06:06 AM
  2. WTB: '80/'81 Celica hood
    By rrabespl in forum Toyota Swap Meet
    Last Post: 02-13-2011, 06:24 PM
  3. WTB: 78-79 Celica Hood
    By jrocknrolla in forum Toyota Swap Meet
    Last Post: 07-30-2010, 08:50 PM
  4. New hood ornament on the RT-105
    By superboosted in forum Toyota Garage
    Last Post: 03-30-2010, 07:10 PM
  5. Looking for a hood for 73 610.
    By 1977ra29 in forum Datsun/Nissan Swap Meet
    Last Post: 12-17-2009, 02:07 AM
