Results 1 to 8 of 8
Thread: need help mx72 cressida wagon 5speed swap
    Oct 2011
    cailfornia chinohills
    25
    So auto trans died and I'm going to be doing a 5speed swap but the one thing is the w58 I got is out of a mkll supra and not the mklll so how much do I need to cut or should I sell it and just find a mklll trans ?
    Mar 2013
    Edmonton, Alberta
    35
    Re: need help mx72 cressida wagon 5speed swap
    dont quote me, but i dont think theres much of a difference. hopefully someone knows. im swapping the W50 out of my MKI Supra with a supposed MKII W58, someone told me that MKI W50, MKII W58 and MKIII W58 are basically the same and interchange besides possibly having to change shifters and driveshafts
    Apr 2011
    TX
    283
    difference is going to be in the shifter position. if you bolt it up and the shifter doesn't line up with your hole (can't be 100% on how an a60 w58 goes in an x7), you can just buy the shifter stuff from an a70 w58.
    any way you cut it, you're going to be playing with how it sits to make it work + - an inch or so.
    Jan 2012
    Spokane
    16
    The MkII w5x shifter position is about 2in farther forward than the MKIII.
    Oct 2011
    25
    So not much then just 2in I would not have to cut to much
    Dec 2012
    Seattle
    23
    Quote Originally Posted by oldschoollove
    Which is still not as good as not having to cut AT ALL...
    Apr 2011
    TX
    283
    also think about shifter position, do you WANT to reach that far forward when shifting and possibly bash your knuckles on the console?
    i've had complete shifter assemblies from jyards for $15, sold some for $75 so there's your price range.
    Jan 2012
    Spokane
    16
    If you are going to use the MKII and cut the sheetmetal a bit, then use the early truck shifter stick. It has a quick dogleg, quite low on the shaft, and will move the shifter back into a more pleasant area.
    Isaac
  1. 1986 MX72 Cressida Wagon Build: "Joby"
    By mr2_ftw in forum Toyota Garage
    Last Post: 07-09-2015, 01:48 PM
  2. WTB: MX72 Cressida Wagon Clear Tails
    By BeanBone in forum Toyota Swap Meet
    Last Post: 07-30-2013, 12:26 AM
  3. mx72 5speed swap ?
    By oldschoollove in forum Toyota Garage
    Last Post: 04-29-2013, 01:20 AM
  4. MX72 Cressida Wagon Tailgate Lock
    By uspspro in forum Toyota Garage
    Last Post: 07-14-2010, 10:28 PM
  5. what 5speed trannys wil fit a 1.8 78 929 wagon
    By rx-7fd3s in forum Mazda Garage
    Last Post: 05-22-2010, 07:20 AM
