Results 1 to 6 of 6
Thread: WTB Corolla GTS LSD rear end
    Aug 2012
    5
    Looking for one of these rear ends with disc brakes to go into my starlet.
    I am in Florida but if you are willing to ship let me know.
    Thanks
    Feb 2010
    Orlando
    213
    Re: WTB Corolla GTS LSD rear end
    Look into the supra mk3 rear end, it's 8 inch and dual lsd
    Aug 2012
    5
    That supra is IRS I need a live axle setup.
    Corolla setup works best as its not too wide.
    Mar 2013
    Edmonton, Alberta
    35
    F313 axle from a MK1 Supra is a common swap into AE86, could work for your situation as well. F313 were SRA with LSD and disc brakes. nearly all US models had F312 open diff but Canadian spec except early 1979 came with F313 standard
    Aug 2012
    5
    The Mk1 is 15mm wider that the Corolla GTS so this may not work either. I know its not lot but the Starlet chassis is not very wide.
    Mar 2013
    Edmonton, Alberta
    35
    there must be a way to make it work, i know alot of AE86 guys that run MK1 Supra rear
  1. Ke30 corolla rear end swap question
    By CanyonRat4age in forum Toyota Garage
    Last Post: 05-19-2014, 10:57 PM
  2. Toyota Corolla TE / KE70 Parts + Rear Wiper Set
    By budoyarle in forum Toyota Swap Meet
    Last Post: 11-11-2013, 03:22 AM
  3. 1975 to 1979 corolla front & rear bumpers
    By 808te31702 in forum Toyota Garage
    Last Post: 09-12-2012, 06:06 AM
  4. Replies: 27
    Last Post: 03-03-2012, 12:26 AM
  5. Rear window weatherstrip for 1980 to 1983 Corolla?
    By billeebee in forum Toyota Garage
    Last Post: 02-12-2011, 12:46 AM
