Results 1 to 3 of 3
Thread: T3 Coilover Conical Upper hat positioning?
    Feb 2012
    Seattle
    19
    OK, probably a really dumb couple of questions here, but here goes. Just finished my weld on coilovers from T3 using shortened stock strut casings from my RA21. However:
    1. ) I cannot figure out where the conical top hat is supposed to sit, does it just rest freely on the top of the spring, or do I used the provided washers to set it on top of the strut rod just below the original suspension support ( or whatever its called, the piece some replace with RCA's ).
    2.) also, once thats figured out, how do you tighten the top nut? it seems to spin the strut rod when I attempt to tighten it, and I cant seem to hold it tight without damaging it.
    Thanks guys, possibly my dumbest two questions, so far...
    Jun 2012
    New Brunswick, NJ
    80
    Re: T3 Coilover Conical Upper hat positioning?
    Quote Originally Posted by vondoom
    Not dumb!!
    I had similar issues and there are many ways round the second one. The hat can just rest on the top of the spring, it will do its thing when the shocks compressed. What I ended up doing to tighten the nut was use a fairly thin open end wrench and hold the little flat part on the strut rod that could be accessed from under the "suspension support". Thats how my kyb struts were designed. If not there may be an allen key hole at the top then in that case you use a socket to hold the nut then put an allen through it to tighten it that way.
    Feb 2012
    Seattle
    19
    Thanks! Thats more or less what i ended up doing!
  1. FS C10 Coilover Sleeves $150
    By ericbauer in forum Datsun/Nissan Swap Meet
    Last Post: 06-23-2015, 04:59 PM
  2. Te27 / ke25 Upper Valance
    By novaluke in forum Toyota Swap Meet
    Last Post: 08-10-2014, 10:54 PM
  3. FS: Two T3 Conical Upper Hats for 2.5" Coilover Springs
    By mr2_ftw in forum Universal Parts Swap Meet
    Last Post: 04-13-2014, 01:34 PM
  4. 2T-G upper timing chain tip.
    By KustomS in forum Resto Tips, Wheels & Other Goodies
    Last Post: 04-18-2013, 10:04 AM
  5. 510 rear coilover kit
    By DeRuX in forum Datsun/Nissan Swap Meet
    Last Post: 03-25-2011, 04:08 PM
