Results 1 to 10 of 10
Thread: help please on my te21
    Guest
    hey guys im new to this forum but so far it seems to be the only forum i can find that i can ask a ? to some guys who know what they are talking about and get a response. i have a 1974 te21 rally car i want to put a new motor in it i want to stay carbuerated and something that will go in fairly easy ne suggestions thanks
    Jan 2007
    3,108
    Why not a 2tc or 3tc?
    May 2009
    Melbourne Australia
    277
    That would seem logical and a perfect option. You could try and source a 2TG but I gather they are hard to come by in the US.
    And a mildly worked 2T is about even with a stock 2TG. Bear in mind that anything you get will likely require a rebuild, and 2TG's can start getting expensive due to poor part availability.
    But my question would be, are you limited in engine selection by class eligibility rules?
    If not, a 4AGE is a common swap in. I honestly would think hard before I went away from a 2T or 3T though.
    Guest
    thanks for your response and i am not limited to size in my class and i will look into those options one other motor i was looking at but dont know how difficult to make it fit is a 22r any suggestions or should i stick with one of the others
    May 2009
    Melbourne Australia
    277
    Well it's been done
    http://www.bigflea.com/corolla/index.cfm?ContentID=114
    You would need to modify your crossmember as you can't bolt in a crossmember from something else with a 22R (too wide). At least the induction is on the opposite side to your master cylinder so you should have room.
    Some of these guys are on 3TCgarage.com I would suggest you have a look through the projects threads for an idea of complexity.
    Guest
    ya i looked at the ones on big flea but no info i will check out the 3tg site thanks
    May 2009
    Pacific NW
    71
    If you really are set on a R series and want to stay carb'd. Might I suggest the 20R-22R hybrid motor. The volumetric effeciency of the 20R head is way better than that of the 22R. If I remember correctly the 20R has around a 70-75% cylinder fill vs the 22R which is sitting around 50%. But the 22R has a bigger bore and stroke so that bumps you up from 2.2L to 2.4L. But the 2 and 3TC do have the benefit of being Hemi heads.
    Feb 2009
    san diego
    2
    bro just go with the 22r tec is really fast and almost perfect fit to a te21
    May 2009
    Pacific NW
    71
    he wants to stay carb'd it sounds like.
    Feb 2007
    SO-CAL
    270
    Just build a 3tc, make it a high compression 89mm block and if you keep it N/A just shot peen and ARP the stock rods. Get a good set of pistons and balance the rotating assembly. Get a good cam and put a basic port on the head. You should get anywhere from 150-200hp with this depending on your compression ratio and carb setup. I've seen basic .40 over motors run very hard in N/A form, and 3T's love compression and cams. The head moves alot of air so you just need to let the motor catch up to it's potential.
  1. Hello from my TE21 and I
    By LeftFootBraking in forum Introduce Yourself
    Last Post: 06-07-2013, 08:44 PM
  2. Looking for some 70-71' te21 parts
    By celicas1 in forum Toyota Swap Meet
    Last Post: 05-22-2012, 12:47 AM
  3. TE21 project
    By greatskinz in forum Toyota Garage
    Last Post: 04-11-2011, 05:53 PM
  4. WTB: the following TE21 parts
    By greatskinz in forum Toyota Swap Meet
    Last Post: 04-01-2011, 01:44 AM
  5. My TE21!
    By Phaze2 Henry in forum Toyota Garage
    Last Post: 12-15-2009, 09:07 AM
