Results 1 to 9 of 9
Thread: sr5 rear
    Nov 2010
    New Jersey
    23
    sr5 rear
    can a ae86 rear fit a te27 with no issues or would i have to fabricate? and how much abuse can that rear hold?
    May 2009
    Melbourne Australia
    278
    Re: sr5 rear
    Not sure what rear axle TE27's came with in the US, but quite likely it already has a T series rear? Therefore you are swapping out a T series to put in a T series.
    Obvious differences are that the AE86 is located with trailing arms and has coil springs and a panhard rod whereas the TE27 has no trailing arms or panhard rod and leaf springs. Other issue is that the AE86 rear is substantially wider.
    It isn't as if it hasn't been done before, i.e in Australia we didn't have T engined TE27's, rather K engined KE25's, and a number of people have gone this route as we have no choice.
    But think seriously about why you are doing it. You need to narrow the diff, discard trailing arm brackets and spring plates and weld on leaf spring plates.
    If you just want rear discs, there are other ways of doing that. If you want to install an LSD, then yes i would do it. But if you already have a T series, you can bolt a zenki LSD centre into your existing rear. Possibly you may need to remove a little from the axles.
    Jan 2013
    Oklahoma, USA
    48
    Re: sr5 rear
    are you asking about just the diff or the whole rear end?
    Nov 2010
    New Jersey
    23
    Re: sr5 rear
    jus the rear
    May 2009
    Melbourne Australia
    278
    Re: sr5 rear
    So the information you need to find out is what type of rear assembly you have in the car at the moment, and what are you planning for the car.
    Nov 2010
    New Jersey
    23
    Re: sr5 rear
    its a regular stock rear
    Apr 2010
    snohomish, washington
    497
    Re: sr5 rear
    The answer is anything is possible with the right amount of money..
    Aug 2012
    Montreal, Canada
    111
    Re: sr5 rear
    Quote Originally Posted by StinkyTurbo
    Look on your vin plate inside the engine bay, by the trans/diff you'll have something like T50/S292 or T292... the S or T is the diff type, 6.38" or 6.7"... if you don't have a vin plate inside teh engine bay look at the diff center to housing flange and count the number of bolt, 8 = S type 6.38"; 10 = T type 6.7".
    Normally only real SR5 had the T type (same as a zenki GT-S AE86) and all the other had the S type (same as all SR5 AE86). As said above, the housing will not swap without extensive modding (shortening, cutting 4 links and welding leaf spring seat). But you can swap the diff center... but don't try to mix diff type, S goes with S and T goes with T.
    Mar 2013
    Edmonton, Alberta
    35
    Re: sr5 rear
    if a AE86 rear will work, maybe consider getting a F313 from a MK1 Supra. common swap for AE86, F313 are LSD with discs and can take some abuse
  1. red R30 rear seats and R31 Hasemi rear brake pads BNIB
    By familycar in forum Datsun/Nissan Swap Meet
    Last Post: 06-13-2015, 06:07 PM
  2. WTB - AE86 GTS rear full LSD rear end for Starlet
    By ct9amr in forum Toyota Swap Meet
    Last Post: 01-15-2013, 11:15 PM
  3. GSL 4.88 rear end
    By savannarx7 in forum Mazda Swap Meet
    Last Post: 07-25-2012, 09:58 PM
  4. F/S 510 rear control arms, fenders,ST rear springs - Seattle
    By tristangay in forum Datsun/Nissan Swap Meet
    Last Post: 06-18-2012, 09:08 AM
  5. ID rear spoiler please
    By onlyCressida4me in forum Resto Tips, Wheels & Other Goodies
    Last Post: 04-25-2012, 04:22 PM
