Results 1 to 10 of 11
Thread: 79 Supra no spark
    Mar 2013
    Edmonton, Alberta
    35
    79 Supra no spark
    shootin it to see if someone might know whats up with my Supra
    long story short, i changed the cap and rotor a couple of years ago before i put it away for winter. in spring when i took it out, it ran fine for 10 minutes until it got warm, then it would jerk like crazy. eventually got frustrated and starting taking things off, dizzy cap i put on had a crack on the back of it
    put a new cap on and it ran fine, took it out for 3 hours and lost spark at 4000rpm. engine died quietly, coasted into a park thinking the distributor went. towed it home, no spark at all from any plug wires. new coil (had the original on and changed it because it was failing) and new distributor. couldnt find anything else wrong, and figured the igniter went bad being original. parts not available anymore because 1979 igniter were one year only, so i wired in a MSD 6AL and wired the EFI wire that went to the OEM igniter to its own relay with a switched 12v source. still no spark
    im thinking maybe ECU? i cant see why its not getting spark though because switched 12 volts is going to the MSD box. if anyone knows 1979's well that would be a huuuuge help lol
    also timing chain didnt break either
    Oct 2011
    Alberta
    171
    Re: 79 Supra no spark
    Still fighting with that spark issue huh? Must be getting frustrating. Keep at it, it's a beautiful car, worth the trouble. If I see you broken down in MacKinnon ravine again I'll stop by and say hi again. :wink:
    Mar 2013
    Edmonton, Alberta
    35
    lol yep, all the months later no dice. i work with a guy that knows old Toyotas so at least hes gonna come over and see if he can figure out whats up. im thinking ECU because the MSD box light flickers when i crank it and its getting power.
    im not going down Groat road again in that thing, a month before you found me stalled in the park, a guy in a SUV with a couple of kayaks on top lost one and i almost smoked it
    Oct 2011
    Alberta
    171
    Didn't you know? It doesn't matter what you're driving, if you're on Groat Road it magically becomes a sports car.
    Good luck with the car, if I find anything at the Pick n Pull I'll let you know, I'll be there a lot this summer for my Volvo.
    Apr 2011
    TX
    283
    if you can't get it running right, send me your rear end. 8)
    Oct 2011
    Alberta
    171
    Also, throw us some eye candy. That thing is in great shape.
    Dec 2009
    southern PA
    278
    does this have the 4me or 5me in it?
    i have two 1980 cressida ECUs, as well as a Dizzy that worked well on my car
    Oct 2011
    Alberta
    171
    His is the 4
    (sorry to speak for him)
    Dec 2009
    southern PA
    278
    its worth a shot looking at the pins/ and what not... i wouldnt see what would be different besides maybe the fuel map/rev limiter stuff like that
    Mar 2013
    Edmonton, Alberta
    35
    sorry for the late reply, been busy. yeah its got a 4ME, i tried a new dizzy already but no dice. ive wanted to pull the valve cover for a while but i havent had time.
    i did buy another vehicle the other day though, 91 Crown Royal Saloon. so at last i still have something fun to drive this summer until i figure out why the Supra has no spark. no other pics of the Supra really, in the years ive owned it ive barely driven it even a few hundred kilometers.
    and sorry not giving up the rear end out of it lol, worst case is i do a engine swap on it. frame and chassis are mint on it. its got a one-off F312 open diff anyways because its very early 1979 Canadian model, only mid 79 to 81 had factory F313 LSD
  1. Help please 1983 RX7 GSL no spark
    By ColoradoKP in forum Mazda Garage
    Last Post: 10-20-2013, 05:26 PM
  2. Spark plugs for a 5M?
    By dan on a plane in forum Toyota Garage
    Last Post: 07-06-2012, 05:03 AM
  3. KGC10 L20 spark plug gap
    Last Post: 07-20-2011, 09:59 PM
  4. Week Spark?
    By The Names Yota, Toyota in forum Toyota Garage
    Last Post: 10-06-2010, 12:13 AM
  5. 1977 corolla no spark
    By bigblackcat in forum Toyota Garage
    Last Post: 07-20-2010, 09:41 PM
