Results 1 to 4 of 4
Thread: engine question..
    Apr 2010
    snohomish, washington
    497
    engine question..
    So I be rebuilding my 2tc. While I'm at it I want to give it a little more all motor power. So I'm thinking of running this cam
    http://www.crower.com/camshafts/toyota- ... -7218.html
    My question is since I will be taking the head to the machine shop anyways I thought I should be oversized valves put in. The question what size should I go with and also what strength of springs? Cause I know to little can hurt power out put and too big can also..
    So any ideas would be awesome.
    Mar 2007
    Pac NW
    500
    Re: engine question..
    Quote Originally Posted by liquid51
    This is not an extreme cam, a good valve job, a nice clean 3-angle, with a back cut. Oversize valves are not needed, but mild port work would be in order.
    A mild compression bump would be beneficial as well.
    May 2011
    Netherlands
    170
    Yes, a sharper cam needs some higher CR, skim the head or a thinner headgasket, otherwise the engine is quite dull in lower rev range.
    Beware for interference, measure the space between valve and piston with kids clay on top of piston and turn engine in a loose mock up state. About 1.5 to 1mm space should be left.
    Apr 2010
    497
    Thanks for the info...I was think of doing the valves and stuff cause I eventually want to do high comp..
  1. 3k engine question
    By parrot in forum Toyota Garage
    Last Post: 06-19-2012, 03:42 AM
  2. Engine question.
    By Chuxa in forum Mazda Garage
    Last Post: 11-11-2011, 02:03 PM
  3. Quick Colt engine question
    By subaru3 in forum Mitsubishi Garage
    Last Post: 02-06-2010, 09:31 AM
  4. HELP ME!!! 5k engine question
    By hypokp in forum Toyota Garage
    Last Post: 08-26-2009, 10:11 PM
  5. Toyota Engine Question
    Last Post: 06-22-2009, 06:08 AM
