Results 1 to 8 of 8
Thread: Documentation of a TE37 to 7M-GTE Swap
    Apr 2010
    Brooklyn, NY
    10
    Originally started with a TC setup:
    I will be swapping this:
    into this:
    I will document each step as I go along. The firewall has been notched 4" and the section has been boxed:
    The original shifter has also been relocated to suit the R154
    The car is plauged with a little rust so progress will be slow.
    Before:
    After:
    Plans include:
    rear-mounted radiator
    3" SS exhaust
    8.8 rear
    4 link
    T70 turbo
    30 x 12 x 3 I/C mounted behind grill
    expansion tank
    modified oilpan
    custom catch can
    shaved bay
    bigger injectors (not decided which yet)
    aftermarket ecu (not decided which yet)
    fuel cell ans external F/P
    swirl pot
    All welding and fabrication will be done by me.
    May 2012
    COSTA RICA, CENTRAL AMERICA.
    192
    Re: Documentation TE37 7M-GTE Swap
    suscribed to this awesome project!!!! :tu: :tu: :tu:
    Apr 2010
    Brooklyn, NY
    10
    Re: 7M-GTE Swap to TE37 SR5
    UPDATE
    The rust repair has gone well and completed:
    Wiring at the start:
    Completed this way:
    ECU and engine electronics in passenger compartment:
    Intercooler hotside piping done:
    Downpipe done sometime ago:
    Wilwood pedals and masters:
    Small teaser:
    http://s83.photobucket.com/user/strfabw ... 3.mp4.html
    Nov 2009
    NYC
    179
    Re: Documentation of a TE37 to 7M-GTE Swap
    This is pretty cool, where in Brooklyn are you located? Im local and would like to come check this out in person.
    Apr 2010
    Brooklyn, NY
    10
    Quote Originally Posted by brownmagic
    I'm in Canarsie. I will pm you my number. I'm doing some work tomorrow so it will be a good time.
    Apr 2010
    Brooklyn, NY
    10
    Feb 2008
    Saratoga N.Y.
    729
    Where You At :tu: :td: :idea: :wink:
    Apr 2011
    TX
    283
    nice job, but what did you do/are you going to do about the oil pump?
  1. noobie TE37
    By syco781 in forum Introduce Yourself
    Last Post: 10-20-2012, 10:56 PM
  2. wtb 76 te37 sr5 parts
    By charlesM3 in forum Toyota Swap Meet
    Last Post: 08-30-2012, 04:42 AM
  3. My TE37 build
    By Tevin1374 in forum Toyota Garage
    Last Post: 05-05-2012, 05:30 PM
  4. TE37 from Washington
    By Tevin1374 in forum Introduce Yourself
    Last Post: 02-27-2012, 09:22 AM
  5. my Te37
    By syco781 in forum Toyota Garage
    Last Post: 11-08-2011, 07:35 PM
