Results 1 to 10 of 15
Thread: 5-Speed Trans behind a 2M
    Aug 2010
    San Diego, CA USA
    44
    Years ago I met a guy with a '67 Crown that had swapped in a 5 Speed instead of the 4 Speed. He said it was an easy swap, same mount, shifter hole, etc. I can't remember what car he said the trans came out of though! I think maybe a 2wd pick up but it might have been a Celica/Supra. Does anybody have any experience with this swap? I'd like to have a little knowledge before I start hunting for the trans.
    Thanks!!
    Jul 2010
    Waterloo, Sydney, Australia
    8
    Re: 5-Speed Trans behind a 2M
    Sounds right.
    Hunt for a W55/W57 (Celica) or W58 (Supra), those 2 car models are probably the most common, than a manual Crown or similiar. The bellhousings/mounts will be the same as what you already got, or you can easily mix and match with your current manual if the W5x you find is not inclusive of everything.
    Im not well versed with manuals but you may need to do some research about the different gearings and things, maybe the W58 isn't well suited to a 2-M, but the W55/W57 from the smaller engined Celica's may be better. Here's a link about different diff gearings & all that hoo-ha. Sounds like it will be necessary http://www.toymods.org.au/forums/engine ... lease.html
    Aug 2010
    San Diego, CA USA
    44
    Thank you! I thought maybe the Celica was the way to go. I'm going for the W55 if I can find one!
    Sep 2010
    australia
    39
    I would say he used a W50 from an early Celica.
    Cheers Brett.
    Dec 2008
    Staten Island, NY or Miami, FL
    131
    Any of the W-series transmissions from Toyota is the answer.
    Not sure about bellhousings or driveshafts though... my guess would be maybe a 7M bellhousing? But don't take my word for it.
    Aug 2010
    San Diego, CA USA
    44
    Thanks for the advice guys! I found a W50 about an hour from my house. I'm going to get it tomorrow. It doesnt have a bell housing so I hope I can use mine.
    Aug 2010
    San Diego, CA USA
    44
    Boooo! I now own a W50 trans but it is in no way a direct swap for whatever the heck is in my car now. The 4 speed in the car now has all the shifter mechanism on the right side with an external shifter shaft. The W50 has the shifter on top with no external stuff. The W50 is also considerably shorter with a different mount set up. I can make a new crossmember and longer driveshaft but I'm afraid that will put the driveshaft into interference with the X-Chassis.
    Aug 2010
    San Diego, CA USA
    44
    Could it be that I have an N-40 in my car? I see the Rock Auto catalog shows both the W-40 and N-40 as options for a '67 Crown with the 2M Motor. I can find tons of info and pictures of the W-40 and none of it matches mine. I can't find any info on the N-40 though.
    Apr 2011
    TX
    283
    did anyone that told him that this would be a direct swap have firsthand knowledge of the transmission being used mating to the engine in question in the chassis in question?
    first of all, i guess you can assume that a bellhousing on a w50 (if it was mated to an M-series motor) should have the same bolt pattern on the engine block side as your 2M. personally I have only dealt with 4-7M motors and their respective A340s and R/W gearboxes.
    second, W series transmissions have a few different bellhousing PNs for M applications and different shifter locations as well. best bet for locating your shifter is bolting up the trans or at least positioning it as close as you can get it to where it "should" go and seeing where your shifter hits the tunnel. If it's not lined up with the original hole, you can either cut a new hole or possibly (again depending on the shifter style of the w box you have and the rear housing on the box itself) use a different shifter plate assembly to move the location back/forward by an inch or so either way.
    here's an excerpt i found of a description for the W50 online:
    "Often called the "steel-case" transmission for its steel shell, in contrast to the later W-series transmissions' aluminium case. This transmission is mostly associated with early Celicas of the 1970s. It is also shorter from the bellhousing face to the transmission mount than the later aluminium case W-series transmissions, despite using the same mount."
    hope that helps somewhat.
    Aug 2010
    San Diego, CA USA
    44
    So I've been looking up everything I can find on an early 5-Speed behind a 2M or 4M motor. It looks like a Corona Mk2 would be a good donor for my project. I don't see anything on Crowns having 5-Speeds and Celicas or Trucks would not have the M series motor. At this point, if I could find the right bellhousing, I think I could make my W50 work. Can anybody think of anything else that would have had the W50 bolted to an M series motor?
  1. 20R engine, manual 5 speed trans, Denver, CO
    By Jonv in forum Toyota Swap Meet
    Last Post: 12-22-2013, 06:45 AM
  2. Wtb mk2, or mk3 supra 5 speed trans
    Last Post: 11-24-2013, 07:56 PM
  3. WTB: W40 or W50 Trans
    By vegascorona in forum Toyota Swap Meet
    Last Post: 10-29-2012, 05:12 AM
  4. LEEN 6 speed adapter: J160 6 speed into AE86 !!!
    By oldeskewltoy in forum Toyota Swap Meet
    Last Post: 09-29-2011, 06:33 PM
  5. L20a fuel injected motor and 5 speed trans feeler.
    By skyrine in forum Datsun/Nissan Swap Meet
    Last Post: 01-19-2011, 06:04 AM
