Results 1 to 3 of 3
Thread: Help carbs back firing
    Dec 2012
    Hi there is done had a bit of a search but can't find anything that helps me out. I recently purchased a toyota 4k and dropped it in my starlet. I'm having a problem. The car starts and idles fine but if I just step on the gas it's just backfires out the carby and exhaust. I can rev it up if I slowly take the revs up, but as soon as I try rev it up quickly it dies. I've checked timing and that's good. Any help appreciated.
    Aug 2011
    San Bernardino, CA
    Re: Help carbs back firing
    check the jets on the carb. might be starving for gas. bad fuel pump maybe psi might be low. put a psi gauge on the line to see if the fuel pump is working properly. Could it be the original pump is not pushing enough for the 4k.
    May 2011
    Check ignition timing, and vacuum timing advance system.
  1. 2tg with sidedraft carbs
    By milks in forum Toyota Swap Meet
    Last Post: 12-05-2012, 05:22 PM
  2. cam and carbs
    By toywagon82 in forum Toyota Swap Meet
    Last Post: 10-20-2012, 06:35 AM
  3. Your opinion: Carbs or EFI and why?
    By UtahSleeper in forum General Discussion, JNC News & FAQ
    Last Post: 05-08-2012, 08:08 AM
  4. Dual SU carbs for 18r. $150 obo
    By rustypanda in forum Toyota Swap Meet
    Last Post: 01-12-2012, 02:47 AM
  5. Replies: 7
    Last Post: 03-11-2011, 09:52 PM
