Results 1 to 9 of 9
Thread: Can a VB 1800 accept an MA crank for a small stroker?
    Feb 2013
    11
    Short story, a friend is freshening a 1974 VB-powered Courier. Pistons are domed but sit 2mm in the hole. 8.3:1 seems too low. He's got a set of .75 over stock-type domed pistons and a long-tube header, Weber and adapter. Daily driver in SoCal.
    I'll do a mild port job, match manifold, good seat work. He's looking for a cam choice. I may make a manifold to head spacer to add some runner length.
    Adding 4mm stroke seems perfect way to get the pistons up to the deck?
    Bearings look to be the same? F/MA? Wiki is vague and I haven't an MA crank to compare to the stocker.
    Will zero-deck work without domes hitting head or valves? It'll be checked for clearance and minor notching is ok for us.
    I'm assuming that 2mm of block cut is excessive and P'sO the tensioner?
    Feb 2013
    11
    Re: Can a VB 1800 accept an MA crank for a small stroker?
    8.3:1 with 4.778cc/mm of stroke and 61.529cc at TDC, 449.165 swept
    Reducing TDC via pistons at +2mm (without stroke change) leaves 51.973 brings 9.64:1 CR
    Adding 4mm stroke for 468.278 swept and 51.973 TDC gives 10.01 which seems OK for an aluminum-head hemi chamber?
    Aug 2012
    26
    I'm going to finish pulling my F/MA out of my 1980 626 this afternoon and hopefully final disassembly after that. Do you need any particular measurements from the from the crank while it's out?
    Feb 2013
    11
    Quote Originally Posted by MrVito
    Please! Pics and journal locations would be great!
    Feb 2013
    11
    Feb 2013
    11
    Please? lol
    Aug 2012
    26
    Got the engine out, but then ended up having to drive a friend 2 states away to pick up a car. Probably won't be able to work on her more until next friday. I'll make sure to post up lots of pics and measurements when I get to it though. Sorry about the delay man!
    Feb 2013
    11
    Haa. No worries. Thanks.
    Mar 2012
    Brisbane
    4
    Try here fordcouriercollector.com
  1. Crank and Piston Feature for my 240z
    By docaam in forum Off-Topic
    Last Post: 04-09-2013, 07:26 PM
  2. Ld28 V07 crank and 9mm rods
    By Jgonzo911 in forum Datsun/Nissan Swap Meet
    Last Post: 01-01-2013, 12:45 AM
  3. questions about a 3.1 stroker
    By mikep1457 in forum Datsun/Nissan Garage
    Last Post: 11-02-2012, 04:41 AM
  4. WTB 6MGE Crank Pulley
    By 82Supra5m in forum Toyota Swap Meet
    Last Post: 04-25-2012, 12:35 AM
  5. 6MGE crank pulley
    By Yotatoy in forum Toyota Swap Meet
    Last Post: 02-22-2012, 09:41 PM
