Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
Thread: 1980 Mazda 626
    Aug 2012
    26
    1980 Mazda 626
    About a year ago I picked up the "Parts List" 626 (http://www.stanceworks.com/2012/05/t...s-mazda-626-2/,http://japanesenostalgiccar.com/foru...hp?f=5&t=15681) from Joseph Dale. I really liked how stock and clean the car was, and the simple effect of lowering it and the great wheel choice Mr. Dale had made gave the quirky little sedan that something special. The engine however, was not in perfect health.
    So when I brought the Mazda home she was burning oil, and leaking from the valve cover. The compression was within 10 psi across all four cylinders, no more than 6 between adjacent cylinders. It was between 138-148 in total, factory new calls for 170. This made me think that a small amount of it was attributed to blow by, but the pcv looked original, and mazda engines are known for having poor quality valve stem seals. I put on the new PCV and was getting ready to replace the valve stem seals with a handy on engine valve spring compressor. I figured while the valve cover was off I'd clean it up, polish a thick raised band on it, and wrinkle black the rest.
    VC off and cleaned.
    Coated in aircraft stripper.
    Stripped
    Raised front band polished
    Wrinkling nicely (crappy cell phone pic doesn't do it justice)
    So then I find myself looking at the valvetrain....
    ...when I realize that the head bolts also retain the rockers and cam on this engine. Once I realized that the head had to come off to do the bit of top end maintenance I had in mind, I considered the mileage and age of the engine, priced machine work and new pistons, rings, gaskets, head bolts, etc, and realized that it wasn't too bad. So in keeping with the by and large original condition of the vehicle, I decided to go that route. So my wife helped me pull off the hood.
    Then we yanked all of the accessories, manifolds, fluids, the little bit of harness there is, unbolted the transmission, starter, and engine mounts.
    That's how the engine is sitting now, loads of crud in the coolant passages, sludge in the oil galleries, and it appears that there was a bit of coolant finding its way into the oil. The pistons also have seen better days. The engine leveler is attached to the block with the old head bolts, and I plan on pulling her Friday for final disassembly. The head pieces and starter are all laid out in front of my bike right now.
    Here is a less than great picture of the carbon buildup/scaling on the valves, this engine has a LOT of sludge in it as well.
    Feb 2013
    11
    Re: 1980 Mazda 626
    Any luck getting the crank out?
    Feb 2013
    11
    Re: 1980 Mazda 626
    Dude?
    Aug 2012
    26
    Re: 1980 Mazda 626
    Sorry, haven't had a chance to work on her at all. Pipes burst under my house, been dealing with that for the last week.
    Aug 2012
    26
    Re: 1980 Mazda 626
    Well, after a busy few months, I've finally got time to spend some more attention on the old girl. I picked up a complete, very well running 1979 RX7 today, the body and interior are trash, but mechanically she's rock solid, starts up on the first time every time with no hiccups, shifts smoothly, has a new clutch, header, alternator, starter, tires and water pump. The plan is to yank the engine, transmission, radiator, and oil cooler next weekend, then begin the transplant process.
    I had been planning on doing a rebuild of the MA, buts parts availability is very low in the states, and I'd like her to have a little more swing in her step than the stock MA can provide. The plan is to try to make the 12A look like it came in the car from the factory, and if I've done things correctly I should be able to easily retain the factory A/C, though we may have to fabricate some brackets for it.
    While I like the low low stance of the car, it is incredibly far from practical while driving. So I'll be making a nice air suspension setup for her, utilizing Universal Air Aero Sport bag-over-strut bags up front, and a traditional airspring/bag setup in the rear, with all of the air management hidden in the trunk. This way I can retain the nice stance while she's parked, but be able to make a right turn with her that doesn't require using both sides of the street. I'll be sure to take a lot of pictures of the whole process.
    Jun 2009
    Melbourne, Australia
    802
    Re: 1980 Mazda 626
    ^ what restoremaz said. If it wasn't for the fact that I can get VC/MA bits for next to nothing, I'd have gone the transplant route as well.
    Mar 2010
    Ballarat
    197
    Re: 1980 Mazda 626
    At least if you rotarize it, a few of us on here know the pitfalls!
    As long as you realise there are NO direct bolt in bits for this conversion,
    you'll be OK.
    Aug 2012
    26
    Re: 1980 Mazda 626
    It seems like there are a lot more of these cars in Australia and New Zealand than we ever got in the states. I know a few folks down there have done rotary swaps, and I'm using a few forum threads I've seen as a loose guide. Fortunately this swap seems fairly simple and straight forward. Though I'm toying around with the idea of separating the original 626 transmission, using the tail housing, mounts, shifter, and transmission internals with the forward case and input shaft from the S1 rx7 transmission. I'm hopeful that I can avoid having to have the driveshaft extended for the swap, as that is the only part of this whole operation I'd have to outsource to a shop. My main concern is that if I do that, it may place the engine block too far back against the firewall. I don't have to worry about steering box interference since the car is left hand drive, but I'm trying keep the air conditioning and heater using factory pieces if at all possible. Hopefully the MA a/c compressor will bolt up to the 12A, or at worst I'll have to make brackets for it.
    Any advice on this path, or am I going to be better off just using the complete RX7 trans and lengthening the driveshaft?
    Aug 2012
    26
    Re: 1980 Mazda 626
    So, no advice or experience with the transmission tail housing idea?
    Good news, most of my suspension goodies are showing up today, and in a couple of weeks, the wife and kids are leaving town for a month. This should allow myself and a friend to get the engine swap done as well as the suspension work. Fortunately the style of front air springs I purchased and the factory 4 link rear means that our fabrication work should be relatively simple.
    Aug 2012
    26
    Re: 1980 Mazda 626
    Also, a few pics of the Donor car before we rip out her heart
  1. Mazda 626 1980
    By guido in forum Mazda Garage
    Last Post: 07-07-2014, 11:41 PM
  2. RHD 1980 Mazda RX7 in San Antonio, Texas
    By Spudenater in forum Junkyard Finds
    Last Post: 03-16-2014, 09:26 AM
  3. 1980 Mazda RX7
    By bert in forum Ad / Auction Finds
    Last Post: 12-26-2012, 12:48 PM
  4. M7 1980 mazda 626
    By jitb in forum Mazda Garage
    Last Post: 07-08-2012, 02:35 AM
  5. 1980 Mazda 626 Series 1 Coupe
    By r100guy in forum Ad / Auction Finds
    Last Post: 03-16-2011, 02:07 AM
