Results 1 to 5 of 5
Thread: Jalopnik's Forgotten Cars: The Mazda Roadpacer (Holden HJ)
    Apr 2010
    Hawaii
    195
    May 2010
    Brisbane, QLD, Australia
    105
    Re: Jalopnik's Forgotten Cars: The Mazda Roadpacer (Holden H
    The story is nearly right. The car was actually shipped CKD and assembled by Mazda in Japan which is why they have numerous unique features that we never saw in the original Holden Premier. It is also a shorter wheelbase and wider track.
    The tie-up was not due to the Rotary engine, but the fact that Mazda Japan assisted in GM and Isuzu coming together in 1971. Isuzu sold the Holden Statesman in Japan under the Isuzu badge before the Mazda Roadpacer came into existance.
    Still, a good article on nearly the rarest of all Mazdas. Only the Rotary Parkway bus and original Cosmo L10A sold in fewer numbers.
    Apr 2010
    Quakers Hill, NSW, Australia
    34
    Quote Originally Posted by mazdajon
    Can you explain how & why this would be done?
    Curious as to the mechanical changes & what the benefits would be
    May 2010
    105
    Quote Originally Posted by jonesyGT
    Because the Rotary engine sits higher in the engine bay than the original Holden V8, they needed to use a two piece tail shaft (Holden originally was a single piece) to meet the correct angle, but that required the rear axle to be moved back slightly to make it all work. I originally thought forwards but have checked the specs online and the Roadpacer is longer not shorter. Holden is 2819mm wheelbase and the Roadpacer 2830mm.
    The specs online do not appear as accurate as I remember as they state the same track for both at 1530mm. I have a brochure at home that I will check the track variation with but maybe I am wrong on the track? I will check and confirm.
    Apr 2010
    Hawaii
    195
    Interesting:
    http://en.wikipedia.org/wiki/Mazda_Roadpacer
    Originally intended as transport for high-ranking government officials, the car was sold in the wake of the first fuel crisis and was not a commercial success.
    Most were sold to government departments and were later crushed, meaning Roadpacers are rare nowadays;
  1. Forgotten Dreams-- 1964 Datsun 1500 Fairlady Project
    By spriso in forum Datsun/Nissan Garage
    Last Post: 08-09-2015, 09:07 PM
  2. Jalopnik has no idea what they are talking about. (R32 impor
    By Kanaric in forum General Discussion, JNC News & FAQ
    Last Post: 02-28-2014, 11:29 PM
  3. The Mazda (RA13S) Roadpacer AP
    By jdm_master in forum Mazda Garage
    Last Post: 04-03-2012, 07:39 AM
  4. Mazda Roadpacer...actual footage!
    By rx4rx7 in forum Mazda Garage
    Last Post: 03-21-2012, 08:08 AM
  5. 1977 Holden TC Gemini Coupe
    By Gem wrc in forum Isuzu Garage
    Last Post: 06-19-2011, 04:10 AM
