Results 1 to 7 of 7
Thread: Squeaky brakes..
    Oct 2011
    Pomona, Southern California
    18
    Squeaky brakes..
    Brakes on my 85 Toyota Cressida(MX73) squeak.
    Brake pads are new and I cannot find the problem.
    any suggestions??
    Thank you.
    Oct 2011
    18
    Re: Squeaky brakes..
    has 4 disc's.
    Administrator JNC's Avatar
    Mar 2007
    Socal
    1,644
    shims? anti-squeal?
    -Matt
    Aug 2011
    Netherlands
    43
    And did you apply some copper grease at the back of the brake pads?
    Oct 2011
    socal
    57
    metallic brake pads, glazed rotors - or warped rotors, the caliper slider bolts getting stuck ( not lubed ), shims,. there are more causes.....
    Oct 2012
    oregon
    160
    what brand are the pads? I manage a brake shop and if you bought the eco brands im not surprised. also the more metallic they are the more they squeek when cold.
    Feb 2009
    Hoquiam, WA
    712
    Don't forget there is a break in period too. New pads will have a rough surface from the factory, and won't seat up perfectly against your rotor's existing grooves until worn a bit, true even if they've been turned on a lathe. Usually more of a grind noise but if you didn't turn your rotors, it can be a squeak. Also, did you grease the areas where the pad backing plate moves against the caliper bracket?
  1. Anyone running big brakes?
    By Robaphent in forum Resto Tips, Wheels & Other Goodies
    Last Post: 05-25-2014, 11:16 PM
  2. datsport R31 struts with big brakes
    By DeRuX in forum Datsun/Nissan Swap Meet
    Last Post: 02-17-2014, 09:08 PM
  3. Big(ger) brakes for second gen Celica...
    By CoronaGTR in forum Toyota Garage
    Last Post: 03-20-2012, 05:20 PM
  4. 79 corolla brakes...help me out!!
    By te31corolla in forum Toyota Garage
    Last Post: 12-05-2010, 10:46 AM
  5. WTB 510 or 240Z rear brakes
    By Old Colt in forum Datsun/Nissan Swap Meet
    Last Post: 05-06-2010, 12:25 PM
