Results 1 to 4 of 4
Thread: Lowering blocks--Corolla Wagon????????
    Jan 2013
    17
    Corolla wagon owners:
    What brand of lowering block are you using? I currently have unknown 3" blocks and they're garbage. I'm looking to get 2" blocks to bring the rear up just a bit.. Any luck with universal blocks, or is there a company that makes specific blocks for the Corolla? I've searched and no luck so far..
    Thanks--Brandon
    Sep 2009
    Los Angeles
    161
    Re: Lowering blocks--Corolla Wagon????????
    What makes the blocks "garbage"? They're either gonna be cast or extruded aluminum or cast iron. I would be more concerned about the quality of the U-bolts. You can get different lengths, diameters, and bend radius U-bolts from off-roading truck shops.
    Also, you might consider getting longer shackles instead of shorter blocks. It might improve the geometry of the rear end a little to have the leafs more parallel to the ground...
    Jan 2013
    17
    The blocks were on the car when I bought it, and the rear end has side to side play. The blocks are a universal style (fit poorly) , and the ubolts are as tight as their going to get . I have not looked into longer shackles as there doesn't appear to be room for them. I'm thinking about having a set of springs made to just remove the blocks from the equation..
    Sylvester, have you used longer shackles on a Corolla?
    Sep 2009
    Los Angeles
    161
    Ah, I see. Sounds like the locating pin in the blocks are gone/missing.
    Unfortunately, no. It was just something I remember reading in a suspension/handling book that said having the spring parallel to the ground would eliminate/reduce roll steer.
  1. Lowering a '76 corolla wagon
    By Rolla76 in forum Toyota Garage
    Last Post: 07-16-2012, 03:59 AM
  2. need help lowering te38 corolla
    By frank the tank in forum General Discussion, JNC News & FAQ
    Last Post: 02-26-2012, 04:58 PM
  3. Lowering the wagon... what gives good ride???
    By n1kt0r10u in forum Mitsubishi Garage
    Last Post: 01-04-2011, 06:49 PM
  4. lowering my 70 corona mark 2 wagon
    Last Post: 12-26-2010, 09:28 PM
  5. 79 corolla lowering. please help
    By te31corolla in forum Toyota Garage
    Last Post: 12-18-2010, 09:08 PM
