Results 1 to 5 of 5
Thread: Cleaner Looking Engine Bay?
    Apr 2010
    Newark, NJ
    115
    I'm thinking about cleaning up my Corolla's engine bay. I'm not looking to do any wire tucking, but instead cleaning it up a bit. There are just too many wires on the positive battery terminal, and I want to eliminate that clutter. I'm thinking maybe a distribution block on the inner fender wall or firewall. Should any of you fellow nostalgic owners have tips and the pics (before/after) to back it up, please do share!
    Jun 2012
    New Brunswick, NJ
    80
    Re: Cleaner Looking Engine Bay?
    ^god bless that post^
    Apr 2010
    Newark, NJ
    115
    Tristan, do you have a sound system, electric fan or other electronics on that car? Because I have too many wires on the positive terminal of the battery. I want to find a way to eliminate all that clutter. Anyone?
    Mar 2011
    North Texas
    43
    Quote Originally Posted by te72_sunny
    Auto electrical systems are supplied and fused through a fuse box and fusible Link Boxes, not additional wires running across the engine bay to the battery. If your fuse box is full, get an additional one.
    A very clean install is to keep a distribution block with enough legs for the heavy items:
    A)from Batt
    B)To Starter
    C)To Alternator
    D)To Fusible Link->Fuse Box
    E)Aux (extra connection)
    Your fans, radio, etc. need will then draw power from the fusible link terminal off your dist. block and then fused at the recommended amperage.
    You can purchase these, but I have made one from a piece of 1/4" copper, drilled and tapped for distribution, and attached to a 1/2" piece of micarta. Use no less than 4 awg for the runs, and ground your engine block to the chassis (like a shock tower) with 4 awg. Your starter and alternator will thank you.
    Most of our older cars don't have fusible link boxes under the hood, but any 80's and newer car in the junkyard should have them. Snag one and run the important stuff directly to this box; ignition, fans, fuel pump, etc. and use the Main to feed the cabin fuse panel, route these wires directly into/along the harness and it will look very factory. At the junk yard make sure to snag the line feeding the box as well as any connections leaving the terminals, that way you can de-pin and re-solder any terminals.
    I'll try to get some pics of my distribution block when I get home.
    edit: I change my recommendations from 2 to 4 awg for the short runs and engine ground. Although I would suggest 2 awg for a rear located battery.
    Mar 2007
    Pac NW
    500
    I found high quality battery terminals
    https://www.google.com/search?q=metra+t ... 96&bih=604
  1. F.E.T. FORZA Reusable Metal Air Cleaner Frame
    By Gumbeaux in forum Universal Parts Swap Meet
    Last Post: 07-01-2014, 01:55 PM
  2. 1973 240Z SU carbs, intake manifold(s), air cleaner, etc.,
    By catalak in forum Datsun/Nissan Swap Meet
    Last Post: 05-23-2014, 05:33 PM
  3. Ford Courier engine simiar to 808 engine?
    By Dave77 in forum Mazda Garage
    Last Post: 09-19-2011, 08:06 PM
  4. RX3 10a Air Cleaner Snorkel
    By cobra in forum Mazda Swap Meet
    Last Post: 10-27-2010, 10:06 AM
  5. Engine
    By Yayoi in forum Toyota Garage
    Last Post: 01-15-2010, 06:48 PM
