Results 1 to 10 of 15
Thread: 1973 Corona MKII dash and gauge redo pics.
    Feb 2008
    Saratoga N.Y.
    732
    Mar 2007
    Pacific
    91
    Re: 1973 Corona MKII dash and gauge redo pics.
    Nice job on the dash! I like the touch of the tach instead of the clock. RA29 Tach?
    You can probably mount an early MX32 or RA21 clock in your console now.
    Feb 2008
    Saratoga N.Y.
    732
    Tack. may have been from 74 celica but i think still same as RA29?
    The one with just speedo and tack gauges.
    Ya I want to add a clock to console,I have 2 that I tried but too small.I think one was RA21?
    Console is now undergoing same process.
    Feb 2008
    Saratoga N.Y.
    732
    New headlight pics. 8)
    Aug 2009
    Spokane, WA
    280
    That's some pretty awesome work. Headlights are a nice touch. Cant wait to see them when they are installed. What are you doing with those rear quarter window louvers? Did you make a cover plate for them or something?
    Feb 2008
    Saratoga N.Y.
    732
    Ya unsure which light combo to go with yet,they may be a little much for the car?
    Ya i made the cover for the 2 side vents.it bolts on with 3 hidden screws.
    Aug 2009
    Spokane, WA
    280
    I would love to see how those side vents look. My suggestion on lights.... don't go over the top. I was going to do projectors in mine but try to keep them downplayed not too flashy or crazy as to take away from the looks of the car...
    Oklahoma City
    762
    first, great work on the car so far. When re-doing your dash, what did you do to fix the needles on the speedo and such. All of mine are bent like yours and I would love to straighten them out.
    Feb 2008
    Saratoga N.Y.
    732
    The white needles are metal ones from the rona.The bent one was from the celica tack.
    You could try heat pressing yours back to shape then cooling quickly with cold water or air :idea:
    I think you could use most any needles from any car if you found a good pair.
    I had to add weight to the backside of the tack needle it was too light.
    Nov 2012
    8
    Heya, looks awesome!
    How'd you get the blower assembly out? I have a 72 corona and from what i see the blower assembly looks similar. I need to change the heater core, blower moter and clean it all up but I'd like to try to do it without ripping out the whole dash. Also, where did you find all the foam insulation strips?
    Thanks!!
  1. My 1973 Corona MKII build
    By Matches in forum Toyota Garage
    Last Post: 08-16-2015, 04:31 PM
  2. 1973 Corona MkII Sedan
    By 3f05q in forum Toyota Garage
    Last Post: 08-10-2015, 03:41 PM
  3. 1973 Corona MKII wagon
    By pertano in forum Toyota Garage
    Last Post: 05-23-2012, 07:14 PM
  4. STOLEN 1973 Corona MkII (Seattle WA)
    By 3f05q in forum General Discussion, JNC News & FAQ
    Last Post: 02-10-2012, 01:10 PM
  5. how to remove a corona mkII dash?
    By yellow_sub in forum Toyota Garage
    Last Post: 10-05-2010, 05:27 AM
