Results 1 to 6 of 6
Thread: got a mk1 supra need help.
    Aug 2012
    st. louis mo
    19
    hello i got this 79 supra a week ago not running . the guy i got it from had the head redone 2 years ago drove around the block and parked it for 2 weeks and when he want to start it again it wouldn't start.
    well after alot of work i got it running but it has a problem, it wont rev past 2200 rpm, almost like it hits a rev limiter. and it runs a little ruff . i think its a timing issue . but any help would be great.
    i got some pictures of every thing,
    this is of the cam and the pointer is lined up with the dowel like it should to be.
    rotor pointing at #1 exactly
    i have the distributor almost to the stop to get to 12*
    here is the timing mark, its a little off, is that a acceptable amount?
    here is a poor video , you can hear it backfire once,its never done that before.
    http://s134.photobucket.com/albums/q...rent=supra.mp4
    new parts,
    engine rebuilt 60,xxx miles ago
    head rebuilt less then 10 miles ago
    new fuel pump
    new fuel filter
    most fuel lines replaced
    new plugs, wires, cap, and rotor
    new coil
    injectors rebuilt before i got it.
    any help would be great. thanks
    Aug 2012
    st. louis mo
    19
    Re: got a mk1 supra need help.
    i changed the igniter to my spare one and now it revs to 3100-3200. this thing is driving me nuts.
    Oklahoma City
    762
    I am thinking that your crank and your distributor are off a tad. I would look at resetting the timing between the crank and the cam and also the distributor all at the same time. Not a hard fix, but a bit time consuming. I have been fighting this sort of thing with my wife's camry. I redid all the front seals and replaced the timing belt. Took me two days to get the crank and the cams lined back up.
    Aug 2012
    st. louis mo
    19
    Quote Originally Posted by OkieRA29
    i have played with it all day and it just made it worse. it must be a electrical or fuel issue become as soon as i switched to my spare igniter it went from 2200 rpm max to 3200 rpm max.
    Oklahoma City
    762
    Either a bad FPR or maybe some junk in the tank/lines restricting fuel flow?
    Aug 2012
    st. louis mo
    19
    thats one thing i haven't done is check fuel pressure, i don't have a gauge. i will switch out the fpr with a spare and see if that make a difference. thanks.
  1. 1989 supra
    By b110prodigy in forum Off-Topic
    Last Post: 09-01-2015, 04:52 PM
  2. My '82 Celica Supra
    By 82Supra5m in forum Toyota Garage
    Last Post: 09-09-2012, 01:13 PM
  3. HELP - looking for Supra flares.
    By kingtoy in forum Toyota Swap Meet
    Last Post: 06-21-2011, 08:26 PM
  4. Old pic of New Supra with Epsilons
    By FjFairlady in forum Toyota Garage
    Last Post: 06-16-2011, 05:40 PM
  5. 85 Supra
    By nikosan in forum Toyota Garage
    Last Post: 10-01-2010, 11:03 PM
