Results 1 to 3 of 3
Thread: 626 brake upgrade help
    Apr 2010
    Hi, I need some advice regarding upgrading the brakes on my 81 CB2 626. The old solid discs are really uninspiring so I really want to fit vented discs to the front.
    Is it possible to fit SA22C front vented discs on my stub axle's, and can I use the calipers from the same car.
    Any thoughts or ideas are welcome.
    Mar 2010
    Re: 626 brake upgrade help
    Hey bloke,
    RX7 stub axle is different diameter and offset to CB2. I went through all this with my 626.
    There is nothing "off the shelf" to suit our cars.
    The quick solution is to fit the whole RX7 strut - providing you allow for adjustable strut tops
    to correct the camber, can live with the front end being a good 3" lower than standard and tyres
    wanting to scrape the guards!
    (I have fully rebuilt S2 RX7 struts sitting at home with new rotors, bearings, pads - doing nothing
    because I fitted them up, HATED how the car looked, and took them back out! :evil: )
    The better solution is save your bux and get a custom set made to suit your car: ... lit=plo13b
    Sep 2011
    Quote Originally Posted by philip
    I would like to second this suggestion.
  1. MX32 Cressida brake upgrade option
    By Banglabhai in forum Toyota Garage
    Last Post: 05-08-2013, 08:14 PM
  2. FOR SALE, rx2 brake and diff upgrade S.A.
    By wilsonbeck in forum Mazda Swap Meet
    Last Post: 08-14-2012, 03:44 AM
  3. MS63 easy brake upgrade?? 71-74 crown
    By ashms63 in forum Toyota Garage
    Last Post: 03-19-2012, 08:45 PM
  4. spacer/offset bracket for Hako front brake upgrade
    Last Post: 12-22-2010, 11:52 PM
  5. next upgrade to the 1200
    By moisabamf in forum General Discussion, JNC News & FAQ
    Last Post: 02-04-2010, 02:52 AM
