Results 1 to 7 of 7
Thread: 5M-GE 2.8GT
    Oct 2009
    MALAYSIA
    6
    5M-GE 2.8GT
    Hi,
    Anyone familiar wz this 5M-GE ?
    1) Does this engine require more than 4 litres of engine oil ?
    I ask this bcuz my foreman just put a 4 litre and check the dipstick and he said ok. He's yooung chap wz a little experience plus never saw or mingle wz a 5M-GE before, i think the engine is older than him....hehe
    2) Does this auto transmission require only 2 litres of ATF fluid for a
    normal service ?
    How much does it need for a full flush ?
    Rgds
    Jan 2007
    3,108
    I think oil is 5qt if you change the filter
    5qt of ATF for a flush too.
    Oct 2009
    MALAYSIA
    6
    opsss....
    conversion from quart to litre.
    5 Quart = 4.73176473 Litre (L)
    i hv to topup another 0.73 litre then....
    thks mate
    Jan 2007
    3,108
    I should add that the ATF flush assumes you are going to lose some in the flushing process.
    Jun 2009
    SF Bay Area
    16
    Oil and filter per the owners manual 85/86 Celica Supra
    5.4 qts/5.1 liters
    Auto trans drain & refill
    2.5 qts/ 2.4 liters
    Jun 2009
    SF Bay Area
    16
    NOTE : Auto trans fluid early Supras use Type F, late Supras use Dexron II
    What year Supra???
    Feb 2009
    Northridge, CA
    169
    You can use Type-F fluid in a Dexron/Mercon app...it will just make it shift a bit firmer, because it does not have the friction modifier package of D/M.
    These so called "racing" ATF's are just Type F with a custom dye added.
