Results 1 to 7 of 7
Thread: Mid engine Honda N600
    I was thinking about a possible project to do. I would start with an N600. Take out the engine in the front, and get a CBR 600 motor. Then, remove the dead axle from the back, keeping the leaf springs though, and replace it with some sort of trike axle with a diff. (Same track) then mount the engine in the middle and run the chain to the diff. What are your thoughts? are there any big issues with the idea?
    Nov 2010
    bakersfield, ca
    49
    Re: Mid engine Honda N600
    Hey Jim.. welcome!
    Do it! What you describe is a bunch of work, but if you're asking questions like this, you know anything can be done 8)
    The whole rear center floor section (back seat/trunk area) will cut out pretty cleanly and leave you plenty of room to work, but many challenges too.. fuel tank relocation (pretty easy), and devising a way to link the engine to the moving suspension (not so easy).. and about 3 dozen other details that will pop up- all of which will test you, and be so sweet once you've conquered them all..
    get a clapped out N and show us how you repower it :wink:
    -ccrunner
    Nov 2008
    Strasburg, VA
    508
    yes. it's not wide enough...
    same concept:
    http://grassrootsmotorsports.com/forum/ ... 452/page1/
    edit: from a handling standpoint..
    Mar 2011
    Monrovia CA
    100
    Mar 2009
    Portland Or.
    186
    you can always do it on the cheap like I am doing
    on this Forum
    http://www.youtube.com/watch?v=-Hck7pWho-A
    Or buy this MINI with a UK produced pro-motive R1 subframe kit for motorcycle engine and Quiafe diff
    http://cgi.ebay.com/ebaymotors/Pro-Moti ... v4exp=true
    Dec 2012
    Snohomish County, WA
    311
    Ill be doing a 1000cc Honda crotch rocket swap in my N600 whenever I can get the time to do it.
    Dec 2012
    Columbia, MO
    5
    I have a 2001 CBR 900RR motor set that would be perfect for this thing. I bought it with the intention of putting it into an MG Midget but then I picked up my Starlet and decided to go nuts on that.
  1. 173 MPG Honda N600 on Ebay!
    By Sven7 in forum Honda Garage
    Last Post: 07-21-2015, 02:47 AM
  2. New 71 Honda N600 on the block
    By 71HondaN1500 in forum Introduce Yourself
    Last Post: 12-29-2012, 12:30 AM
  3. '72 Honda N600 - Bridgewater, NJ
    By gtxtom in forum Ad / Auction Finds
    Last Post: 12-04-2012, 10:25 PM
  4. help with n600 engine problems!!!
    By mike93hatch in forum Honda Garage
    Last Post: 09-15-2011, 04:24 AM
  5. Honda N600's
    By rustyra24 in forum Ad / Auction Finds
    Last Post: 08-02-2011, 10:28 PM
