Results 1 to 4 of 4
Thread: Power Steering in a 1977 Celica (RA29)
    Dec 2012
    Tucson, AZ
    7
    I see that there are power steering pumps and reservoirs available for my RA29, but I'm not sure what else I might need to do to install power steering on my car.
    My Celica has the original R20 engine and hasn't been modified at all in regards to what's under the hood.
    What else would I need to do to make this happen? Is it even possible?
    Oklahoma City
    762
    Re: Power Steering in a 1977 Celica (RA29)
    The 2nd gen pump and rack are supposed to be a direct bolt in affair. One of the guys over on Classic-celica.com was asking the same question.
    Dec 2012
    Tucson, AZ
    7
    Found that thread! http://classic-celica.com/modules.php?n ... r+steering
    So I know I need a pump, PS gearbox, and a rack.
    Would this all work with the 20R engine? What else would I need?
    Oklahoma City
    762
    Yes it will work with the 20R. The only other thing you would need is the bracket off a 20/22R/RE that has power steering for the pump. I haven't looked at mine in a while, but I believe that it replaces the air pump on your 20R. Should bolt right up to the 20R as they really didn't change the basic stuff on the block... yeah, yeah, yeah I know, they changed the deck height and the timing chain, blah, blah, blah... They didn't change the way the timing cover or most of the accessories mount to the front, so your bracket will bolt right up.
  1. FS: Toyoda - Power Steering Assembly
    By mongze78 in forum Toyota Swap Meet
    Last Post: 03-11-2014, 11:55 AM
  2. ra29 1977 short stroke rear shocks?
    By Yotarola in forum Toyota Garage
    Last Post: 06-07-2013, 02:57 AM
  3. WTB: TOYOTA CROWN Power steering pump. AUSTRALIA.
    By Rainman in forum Toyota Swap Meet
    Last Post: 10-09-2011, 11:00 PM
  4. electric power steering
    By robakun in forum Toyota Garage
    Last Post: 09-18-2011, 03:37 AM
  5. power steering for the fairlady z 72 model
    By dice in forum Datsun/Nissan Garage
    Last Post: 07-21-2010, 03:34 PM
