Results 1 to 5 of 5
Thread: omori mechanical gauge (dumb?) question
    Aug 2008
    SoCal
    600
    Hi all,
    My car came with a couple Omori older (& now discontinued) 60mm mechanical gauges for oil temp & water temp and I am looking to move them without tearing up my whole interior...
    Looking at the back of either gauge, I've unscrewed the thumb screw that secures the protective curled wire over the stiff (brass? copper?) "sending" wire..
    But I can't seem to pull the stiff sending wire out of the gauge... is it not supposed to come out?
    If it doesn't come out then what's the point of this thumb screw? What role does it serve?
    Does that mean I have to chase the "sending" wire all the way to the engine, unhook it there, pull it out of the engine harness in order to move the gauge to its new location?
    Thanks,
    I feel like I'm doing something wrong here...
    Mar 2011
    North Texas
    43
    Re: omori mechanical gauge (dumb?) question
    Don't know about that brand, but the sending wire in similar gauges is attached permanently to the gauge body. Even gauges with hollow capillary senders have to be moved from the sensor side. Loosening them from the gauge can mess with calibration.
    Is it routed through the actual harness? I would separate those anyway, ran in their own conduit.
    Aug 2008
    SoCal
    600
    Ok, thanks Aaron...
    So the thumb screw in the pic was only used when the gauge was manufactured then, right?
    Sep 2007
    Grass valley , CA
    442
    I think the thumb screw is just en extra safety so the tube doesnt break right there. My old autometer mechanical water gauge was on piece too.
    Dec 2012
    Summerville, SC
    16
    That's a capillary tube thermometer; similar to the old Smiths used in Brit cars. The thumb screw keeps the protective sheath over the capillary tube. It prevents vibration fatigue and most kinks that would crush the tube..
    Remove the bulb sender from the block and take the whole thing out as a unit. Be careful that you don't crimp the tube.
  1. Dumb dumb question: wheel archs, square or round?
    By Sideglide in forum Off-Topic
    Last Post: 08-13-2014, 05:36 PM
  2. Dumb Question About Gated Shifters...
    By Dachshund in forum Resto Tips, Wheels & Other Goodies
    Last Post: 12-27-2011, 05:47 PM
  3. WANTED - Omori mechanical oil pressure gauge
    By Datsunrally in forum Wheels Swap Meet
    Last Post: 12-15-2011, 04:06 AM
  4. omori gauge diagrams
    Last Post: 09-03-2010, 02:12 PM
  5. Dumb newbie question
    By phuc_difino in forum Toyota Garage
    Last Post: 10-24-2009, 03:28 AM
