Results 1 to 9 of 9
Thread: Mitsubishi 1983 Gj Sigma turbo! (From Australia)
    Oct 2009
    Colac, VIC Australia
    9
    Hey guys its Matt here again just leting you know that i also have a GJ SIGMA turbo as well it runs a 2.6 block with forged pistons and bal bottom end and i also have put a later model injected Magna head on it as they have bigger inlet ports, 45mm Weber and water/methnol injection it also has a supra 5 speed and a ford 9 inch Lsd diff as for quater mile times it has run a 11.89 @ 116 mph so its a bit of fun too. :P
    how does the carb's induction sound like, when the turbo is spooling at the same time?
    Jul 2009
    Germany
    19
    Forgot about cars running Turbos with carbs, could be idea for my other LT that I can't sem to get running properly.
    Seen some pressurised carb systems, but with yours having the fuel go through the compressor, does this cause any problems ?
    Jan 2007
    3,108
    Nice.... I really dig this body style.
    Jan 2010
    Australia
    25
    Very nice Sigma!
    Mar 2010
    Philippines
    55
    Turbos with carbs
    Very nice engine setup. Can you give more details about the engine please? Like how's that setup going so far?
    Feb 2008
    scappoose, or
    754
    Oh man, nice setup.l I'm trying to gather the parts for a factory turbo setup right now? Does that 45 offer much better fuel than the solex?
    Shaun
    Aug 2009
    Varna,Bulgaria
    39
    Cool engine, looking like new. How clean collectors? my starting to rust and I want to brighten them somehow ...
    Jun 2009
    Queensland, Australia
    72
    Quote Originally Posted by LT2000EX
    i've run a few suck through systems myself, on isuzu G series motors.. the fuel running through the compressor draws the heat out of the charge air, basically a chemical intercooling effect. the only downside to this is that in cold climates (ie under 5 degrees centigrade) you can end up with the throttle plate icing up to the point it sticks... so its a good system in hotter climates, not great in snow. and you cant run a normal intercooler system as it will turn into a bomb if u have a backfire. happily though water/methanol injection was invented, so you dont need any other type of intercooling..
    over here grant williams FC RX7 tube frame drag car was running high 7's with a suck through carby turbo 13B about 10 years ago, running methanol. so yes they have mega power potential!
  1. Mitsubishi Sigma
    By melvin in forum Mitsubishi Garage
    Last Post: 08-11-2015, 09:57 PM
  2. "Uncovered" Australia Sigma Turbo Concept car
    By GTS-Retro in forum Mitsubishi Garage
    Last Post: 04-09-2012, 02:30 PM
  3. My Mitsubishi Collection - GJ Sigma Wagon
    By brend0n in forum Mitsubishi Garage
    Last Post: 08-20-2010, 05:55 AM
  4. Mitsubishi Sigma info ?
    By zulu in forum Mitsubishi Garage
    Last Post: 04-11-2010, 08:43 PM
  5. 1988 mitsubishi galant sigma
    By in forum Mitsubishi Garage
    Last Post: 09-05-2009, 05:17 AM
