Page 1 of 11 123 ... LastLast
Results 1 to 10 of 107
Thread: 1986 Subaru Leone STi Turbo
    Nov 2012
    Hamilton, Ontario, Canada
    110
    1986 Subaru GL-10 Turbo AKA Leone (italiano)
    we start of with a stock 1986 Subaru GL-10 FWD TURBO orig 28,000kms 17398.miles. weight is 910kg 2002lb car !!
    the parts car for awd and 5x100 86 xt6
    so what we have hear is to add the 4WD system into one of these cars, those are 20MM sway bars, above the sway bars is what holds the diff, about that is a mix and match of old and new to hold the STi 6mt, above that is a updated version of control arms to hold the 5x100 knuckle.
    rear axle XT6 for the R180 3.900, there is a trick to these where i mix the outer with the new style inners to run a R180. or i could just stay light weight and put a R160 in it.
    cusco motor tranny mnt
    ARP head studs, Cam & Crank sensor new oem
    Spare EJ22T Built @ SUBARU TECNICO INTERNATIONAL
    Nov 2012
    110
    Re: 1986 SUBARU LEONE STi TURBO
    just got a little eye candy from Jon at full race coming soon !!
    Well got half the brakes sorted out for the project
    Nov 2012
    110
    new turbo set up full race twin scroll
    Nov 2012
    110
    Nov 2012
    110
    so got a little oem new parts in today xt6 wheel bearings, xt6 steering tie rod, mustache bar bushings, and new diff support. also have 2006 wrx 2pot rear backing plates, but i sent them out to a friend's machine shop to make a ring for the centering ring
    so parts list is
    VER 8 Sti complete
    Vi-PEC V88
    EXEDY ?? dont know yet maybe multi plate to hold the power
    SPARCO seats: maybe, kind of want it stock but need support lol
    Rims: gc8 and volk jdm if i can find them
    Tire's : RACE SLICK lol for evey day haha !!
    new rotor pads that wont stop this much power to weight lol
    my rear control arms, that me and my dad had to make a tool becuase no one on the plant has one lol
    little thermal coat so then i can wrap them
    got some tubes to make my wastegate pipes longer away from everything
    Little powder coat action
    Got my 2006 wrx backing plates all fixed up so they can fit on the hub the xt6 hubs as instructed from Suberdave !
    So I went and picked up a Jdm spec c version 8 (maybe type RA?) motor swap Ej207DW7ER TY856WB6JA for heads and tranny diff and way ever else I need to twist my leone in to pretzel lol
    Also I was driving to see the boys at Nvauto and I seen a gc impreza on top of another car scrap yard ! so I found the rims I wanted for a steal 250. So I sent them out to the sand blasters to get ready for the powder coating. I'm thinking world rally blue color for the rims
    started stripping for what i need
    EJ22T built bottom end, JDM EJ207 STi Version 8 Type RA heads all oem !
    finished wrapping my headers and turbo
    and got my PURPLE KUSH rims back from the powder coaters, two more sets to do with other crazy colours
    Nov 2012
    110
    test fit my full race twin scroll kit
    also so i just got this hood in what should i put on it ? what type of vents ? side ones or scoop it or cut it and make vents up the middle
    some thing like this and a scoop ?
    also got the sti key to work, i went to home depot cut the key and it worked perfect
    Exedy twin plate HD is ready for the power
    HSD coilovers are here with extra rear mounts
    Tial BJ VALVE
    The Subaru Gods said Let there be ROCK ! AC/DC DC/AC DCCD control !!!
    factory gl-10 flares
    well well well look what has the same shape as the gl-10 !!! do i see 245 45 16 in the future ?
    also a sneak peek at my military grade aviation 1 plug engine harness plug which connects my subaru tecnico international built EJ22T motor to the V88 ViPEC ECU. Custom made by Franz diebold @ diebold autosport
    well no room for a FMIC kit so next best thing !! AWIC..... i got a hole spare tire room for this set up, its even nice and light weight.
    the rad which will be mounted like this cut weld the cap off
    bosch pump and cap
    well my PRODCCD is in ! thanks Jeff @ PRODCCD for helping me out !! amazing high quality product cant wait to put it to good use
    some whiteline race tranny mount bushings with a cusco tranny mount. this cross brace is a mix of old 1986 subaru XT6 with center section new school to make the STi 6mt fit.
    all ready to go !
    water cooler intercooler rad ready to go, core was pressure test also no leaks !!
    well i had to get this not a super fan of gold rims but its a subaru thing and i had to ! some thing like 13lbs is a must on a light weight Leone Turbo monster !
    JDM GC8 STi RAY'S TE37 5x100 16x7 ET53
    well this was Franz's idea on welding the cap set up and my Tial Bov set right on the AWIC and it turned out F amazing
    and push lock hose PARKER and fittings PARKER which cost more then the hole awic set up LOL
    also this came in my new calsonic OEM 1986 subaru gl-10 turbo radiator 5mt version.
    real JDM LOL
    my STi clutch slave & 4 Port brake master all OEM factory brand new Subaru.
    well my spal made in italy fans came in
    mounted ready to drop in.
    a special treat the front OEM Subaru front skirt for my car brand new ! slice the wind !
    had to put it on just did it
    it has started ! tomorrow drop motor tranny in start work on other things.
    new clutch set up and brake cyl.. pedals in also
    motor tranny full race in and fits perfect with out doing anything. just need to make a tranny brace its a little different but piece of cake !
    i was thinking it was going to be a tight fit ! there is lots of room might put a bigger rad if the oem stock one pops !
    full race twin scroll fits perfect
    moved the power steering lines out a little ! all better now
    clutch all ready
    full race fits nice !!
    STi 6mt fits perfect just need to make a brace and its good
    new style pedal box in and ready need to make a gas pedal, and a bracket way up top.
    Nov 2012
    110
    well this just worked out perfect ! its like subaru new i was going to stick a water pump for my AWIC set up.
    Bosch 044 fuel pump, need some angle fitting and done.
    rear mustache bar is ready to hold the R180 just need to make a bracket for the front of the diff and done.
    well this is the tie rod problem taken care of, its simple and works perfect like !
    top is xt6 legacy impreza
    middle gl-10 turbo
    last is whiteline new style
    what you do is chop the end off so you can toe in the car like factory !
    light weight knuckles ! top secret so the competition dont know !
    4pot ready for action ! brembos maybe in the future but who cares really when your going to be this light and fast lol
    rear just started so sunday all done.
    the rear suspension is all old school up top and coilover down town, ill show how i did it very easy to do and keeps all the oem rubbers for when i pick up the ladys and its a nice soft ride !
    HeLLaFLuSH for all you pimping OG's out there !....... these wheels are just to roll it out the shop on monday ! i like to go HELLaFAST LOL.
    bed time
    well rear is all done suspension knuckles and rims tires
    and my amazing light weight battery came in and its in my winter beater to keep it warm for when the Leone is done
    my old school momo hub found in germany !!!
    flowmaster hush muffler !! only thing that can fit on this little car !
    this is what my tip will look like after i weld it all up. but with a foot of pipe in the middle of the two.
    my pipe 3' 304 polished
    shifter plate is all done bolts in.
    my LC1 is ready to auto tune and get me going till Franz comes and really dials it in
    and the diff is mounted in ready to go
    the bracket my father made extra strong so the diff dont end up down the street LOL
    my brake lines all made up this is the rear it has 2 sections that i got made.
    front brake lines done
    and the diff fluid is ready to be add
    Nov 2012
    110
    support for the front lip, oem subaru
    Nov 2012
    110
    put them on
    Nov 2012
    110
    Franz crazy at work on my wiring, this is only half the paper work on my stuff.
    and the pin for the wiring he is doing for my hole car !
    r180 read for service !
    my brand new Bosch 044, these fittings are from the UK for the ford cosworth ! who would have guessed the Leone had the same set up !!
    my hsd front camber plates came in ! thank you JRP for letting me do what i had to do to get my suspension all sorted out !!.
    the front is a bit to low, which will come up after corner balance and aliment get worked out. i wouldnt want the honda crowd thinking i want to race lol.
    i didnt want to add this but i need a bigger opening or else i could not use 2nd 4th 6th or R gear !.. so STi plate with boot, just waiting for the bolts to come in now.
    AWIC pipes and other bits which is moving along nice and smooth. couple back order stuff which is killing me ! summer is all most done.
    clutch line made fluid and bled, ready to go
    this picture is just crazy all in its self !!! it makes me not even want to drive this car and put it away for another 26years !!!!
    Franz Diebold wiring Diebold Autosport ! its just so beautiful i am speechless !! thank you Franz.
  1. 1986 Subaru GL-10 AWD Turbo Wagon
    By J3wman in forum Subaru Garage
    Last Post: 02-15-2014, 05:11 AM
  2. 1986 Subaru GL10 AWD Turbo
    By nfelge in forum Junkyard Finds
    Last Post: 12-18-2013, 06:30 PM
  3. Subaru XT 1986 4WD Turbo 1.8
    By carlo78 in forum Subaru Garage
    Last Post: 05-11-2013, 06:59 AM
  4. 1986 subaru xt turbo - CL, Portland, OR
    By Toy_Yoda in forum Ad / Auction Finds
    Last Post: 03-28-2012, 11:05 PM
  5. 1986 Subaru GL-10 4WD Turbo
    By Alvin in forum Subaru Garage
    Last Post: 12-25-2011, 12:33 AM
