Results 1 to 8 of 8
Thread: Help needed on 1971 toyota crown brake master cylinder
    Oct 2012
    Pendleton, OR
    14
    I picked up a 71 MS55 a while back and when i started working on it i noticed the brake master cylinder is leaking from the rear seal (inside the car). I was wondering if any other toyotas would interchange parts, i went to see about getting a new one or a rebuilt kit but no luck. Any info on interchanging parts or where to get a new or rebuild would be appreciated.
    5,529
    Re: Help needed on 1971 toyota crown brake master cylinder
    Jun 2008
    Torrance CA
    277
    Yeah they are available all over the place. I got one at napa! 12 bucks!
    Oct 2012
    Pendleton, OR
    14
    All I can come up with is master cylinders up to '70, if those will work i will order one tomorrow ($15) just unsure on it working. robakun, do you know the NAPA part number, or can you look it up from when you bought it, if i have that i can go to my local NAPA and get one. I just want to get a new one so i can drive it some before the weather turns bad
    Jun 2008
    Torrance CA
    277
    The 70 should work.
    Oct 2012
    Pendleton, OR
    14
    Alright, just ordered it! hope it works so i can get it soon and on.
    5,529
    The MS55 is tricky because '71 is a split year. Early '71 is S5 Crown, late '71 is S6 Crown. So the large majority of parts you need will be from a '67-70 Crown. Most of the '71 parts will be S6 stuff (usually says '71-74).
    Luckily for you, your car has the bigger S6 car's engine, but all the consumables should be the same as a '70. :tu:
    Oct 2012
    Pendleton, OR
    14
    Such a good thing to hear John! Other than the master cylinder this thing is ready to drive, until i start into modifying it :lol:
  1. Brake Master Cylinder for '71 Toyota Crown MS75
    By toyoglide71 in forum Toyota Garage
    Last Post: 10-27-2013, 09:18 PM
  2. Replies: 7
    Last Post: 10-05-2013, 03:42 AM
  3. WTB: factory mazda rx-3 master brake cylinder or rebuild kit
    By rotary_coupe in forum Mazda Swap Meet
    Last Post: 11-24-2011, 07:23 PM
  4. replacement brake master cylinder for 70 corona
    Last Post: 06-14-2011, 01:53 AM
  5. Toyota RT72 brake master cylinder
    By mark corona II in forum Toyota Garage
    Last Post: 11-15-2010, 06:10 PM
