Page 1 of 5 123 ... LastLast
Results 1 to 10 of 50
Thread: 1978 mx32 Cressida project
    Oct 2012
    oregon
    160
    Hello,
    So about six weeks ago i picked up a 1978 cressida off a craigslist add in West Linn Oregon for $500, it had been sitting from the 2nd owner who has owned it since 83 and it was her first car. She never sold it and did not want to sell it to anyone who would not want to restore it so i had to prove that it was my plan to do so!
    It had been hit in the front and the driverside fender had some kind of rusty heat cracking action. and some other dents on the passenger side fender and doors. other then that, mint condition interior! ugly brown but that will be resolved.
    My plans are a 2jzgte auto, mk1 supra rear end or another idea i got from another member. rolled an pulled fenders, stitch welded, and Im getting bumpers for a swap to get rid of the parkbenches.
    My cluster will be swapped with an IS300 unit, but thats to come.
    when i got it.
    starting to pull the damage out
    starting on the front fenders, flares and body mods
    still pretty rough but getting there i dont have much time to work on it!
    Apr 2011
    TX
    283
    Re: 1978 mx32 Cressida project
    okay.
    so how did you prove you're going to restore it?
    why spend the money on a GTE motor if you're just going to leave it auto? guessing that means JDM aristo motor. what are you doing about subframe/steering? stock?
    do you have a line on a mk1 supra rear or know where to get them? they're getting harder to come by.
    you're going to use an is300 cluster? why is that? do you have the wiring figured out to make it work? what are you going to do about the idiot lights and CEL you're going to be throwing? just ignore them?
    Oct 2012
    oregon
    160
    i proved it by showing her pics of my z project. and my wife talked her ear off about me and my restoration projects.
    I am not worried about wiring, I have wired very difficult swaps before and its not hard to get factory diagrams and read them properly.
    I want auto because its just going to be a cruise car and i might drag it once in a while. plus my wife loves the car and what its going to look like and will probably drive it too. and getting the valve body reworked for a few hundred bucks makes all the difference. a big heavy duty clutch and her will not be friends, I am not going to hook everything up on the cluster just the essential systems. so idiot lights wont be a concern.
    using in IS cluster so i have a speedo, a digital tach and im using an is300 gas tank and sending unit anyway.
    the only reason im going 2jzgte is for cool factor and it pisses my friend off who has a 1jz cress lol.
    im still working out the steering and probably going to put in a rack and pinion plus a collum from a mk3 supra.
    brakes will most likely be z32 calipers so i have better clearance for wheels.
    ive already got a mk1 rear lined up because my friends father has a bunch of junk cars in his field and he has one. plus there is another at a local wrecking yard on there shelves.
    Apr 2011
    TX
    283
    is that LSD or non on the mk1 rear ends? what kind of prices are you thinking on them? what kind of diff are you going to be using that can handle 2jzgte power?
    link to your z build?
    why mkiii supra rack? there are other options that would probably be easier and better suited to your chassis. don't ask how i know.
    what else have you wired? the reason i asked specifically about the is300 cluster is it seems like additional/unnecessary work. is the motor you're looking to get vvti or non?
    teach your wife to drive stick, that way you can force her to drive your car home from the bar.
    are you planning on reinforcing the body with more than stitch welds?
    the z32 brakes mean you'll be looking into at least 16" wheels, i think i heard that there are a few 15" that will clear them, not sure though. so do you have any thoughts on what wheels you're going to try to run? who is making your adapter spacers and hubcentric rings for the z32 brakes? what master cylinder are you thinking about running to go with them? guessing you're going with the T3 front suspension?
    every once in a while you see jdm bumpers pop up on yja, is that what you're going to do to ditch the 5mph bumpers?
    Oct 2012
    oregon
    160
    The bumpers are from a secret source that I'm not willing to divulge until I get my bumpers first.
    The is300 cluster is just neat. And I have one with pigtails already. That's basically why.
    The z32 brakes will clear some 15s and I don't have to run them I'm just still in creative stage. I might run fc calipers either who knows.
    Both rears are only something like $100 and the size that I cant quote right now I can get a kaaz that will work, I have heard.
    Or I might go the s10 rear axles another member here runs on his or even a gsl-se rear if I can find one.
    Ill do pics of my reinforcement as I go along but I will be adding a few bars but no cage.
    I am just fine with the auto. It's cheaper, easier, and its not a sports car I don't need to "bang" gears to justify it being a fun car. It's an age things lol I never wanted an auto before!
    My z build is not being Internet documented due to the fact I would like to some something semi original when completed for at least a month lol.
    I agree there are other options I. The rack that will be quicker ratio. But it's not something I need, and I have the parts already and Ivan always change it later if I need to.
    I've been wiring swaps, doing engine management systems like haltech and mega squirt, chipping ecu's, fabricating, for just about every import brand, for about 10 years I can handle a non vvti swap I am sure.
    Apr 2011
    TX
    283
    pretty sure i'm staying auto for my x3 plans as well, but i'm pretty set on the 1uz. i'm just going to get cheap aftermarket dial gauges and build a housing for a cluster. i need a mki axle for the discs and enough of a rear end to hold up to the v8.
    i have a pretty good idea on what kind of bumper i'd use that i can find in any junkyard. it's been done on other x chassiss but not any x3s i've ever seen.
    i'd like to avoid having to do more than stitch welding and some reinforcement here and there, mostly i was thinking about beefing the frame rails so i can stick a hitch on the back of the car at some point.
    i have a friend that has made z32 adapter pieces for x8s and FC adapters for ae86s. his stuff is really nice, he actually made some NRCA's for my x3 that i have yet to put on. i really don't want to run bigger than 15" on the wagon, the 14" on there now look a little small but that may be ride height/tire more than anything else. if I find a decent set of wide 15s i might consider bigger brakes up front.
    i have a good contition '79 front grille and surround i want to swap for an equally nice '78 piece if you come across one.
    Dec 2009
    southern PA
    278
    hey man still have the 80 style front but shipping is going to be super expensive to the west coast
    Oct 2012
    oregon
    160
    The stitching I've done so far has made a drastic improvement an I only have one corner done, I did over 130 stitches just on the passenger side front. Ill post pics later. I considered 1uz but decided against it.
    Sschasis I've basically already fixed my front so I'm set as far as that goes.
    Jun 2009
    Lynnwood, Washington
    349
    1uz it :tu:
    Oct 2012
    oregon
    160
    Why don't I do a 2jzge too and copy everyone else? I already bought my 2jzgte so I'm sticking too it!
  1. Tinkerer fledgling; my first project, 1978 Cressida RX30
    By Stinkoman in forum Toyota Garage
    Last Post: 08-27-2014, 06:19 PM
  2. my first car/project 1980 mx32 cressida
    By Jelly in forum Toyota Garage
    Last Post: 11-15-2013, 05:31 PM
  3. 1978 MX32 Cressida from TX
    By Banglabhai in forum Introduce Yourself
    Last Post: 11-12-2013, 03:37 AM
  4. step 1 on the MX32 project x
    By ni8kid in forum Toyota Garage
    Last Post: 02-07-2013, 10:53 AM
  5. mx32 cressida help?
    By SOdrifter in forum Toyota Garage
    Last Post: 05-18-2010, 12:11 AM
