Results 1 to 10 of 18
Thread: 74 Peanut engine choice needed
    Oct 2012
    Ohio, USA
    22
    Just purchased this 74 Corolla Peanut. I am a Honda guy. Love CRX's. So I am lost with this classic. Car does not have the engine but everything else is there including the 4-speed trans.
    I have been agonizing over engine choices. I have medium engine skills. I was thinking a 16v 4age, but now thinking a 20R.
    Any help would be appreciated.
    Sep 2012
    BC, Canada
    32
    Re: 74 Peanut engine choice needed
    3tc is a good start. parts are cheap and readily available. Also will require minimal supporting parts to get running since it's carby and not overly powerful.
    Oct 2012
    oregon
    160
    carbed 4ag, anything fuel injected and your going to have to change the fuel setup 100% for a return line and high pressure pump. worth it in my opinion tho.
    i would do a blacktop 20v if i had my choice.
    3tc not bad but expensive when it comes time to make power.
    Oct 2012
    Ohio, USA
    22
    Where are parts available for t-series engines?
    Nov 2009
    FLORIDA
    22
    3tcgarage.com and brdracing.com are a good sorce.
    Nov 2009
    Minnesota
    96
    3tc is not that expensive to get power from. A guy in Hawaii has a 3tc in his peanut and runs 11's with only a weber 32/36 blow thru setup, stock internals other than a small norris cam and maybe valve springs. PVC intercooler piping. If you know what you are doing you can make it happen. 3tcgarage is a great place to get info on the 3tc engine. 4age is the expensive engine to build. 3tc is bolt in as well.
    Jul 2012
    Medford, OR
    16
    I'm gonna jump on the band wagon and say the 3TC is the biggest bang for the buck in an early Corolla. It's not hard to make 200 hp out of a 3TC and that makes a 1900lb car scoot.
    Oct 2012
    Ohio, USA
    22
    There are two 3tc engines in my area. I will look at them both this week and hopefully pull the trigger
    Jul 2011
    Adelaide, Australia
    71
    Blow Thru 3T for the win
    Nov 2009
    Minnesota
    96
    Back in the 90's my uncle swapped a 3tc in his GTS because he priced everything out to build the 4age and it was insane. He ended up experimenting with blow thru turbo setup
    [/quote]
  1. '74 Peanut Resto-Mod :)
    By RotaSpinna69 in forum Toyota Garage
    Last Post: 04-25-2012, 06:34 AM
  2. Toyota K3-VE2 Engine Information Needed
    By mbmdcars in forum Toyota Garage
    Last Post: 03-26-2012, 02:25 AM
  3. muffler choice
    By Nic#66 in forum Toyota Garage
    Last Post: 06-05-2011, 12:24 AM
  4. new wheel choice
    By sarinas_dragons in forum Resto Tips, Wheels & Other Goodies
    Last Post: 10-14-2010, 07:16 PM
  5. Mr. Peanut
    By pappy in forum Toyota Garage
    Last Post: 02-22-2010, 03:40 AM
