Results 1 to 3 of 3
Thread: Steering box corolla ke30
    Oct 2012
    Porto, Portugal
    8
    Someone can help me, how to adjust a steering box from an Toyota Corolla ke30 1976.
    Thanks.
    Aug 2010
    PERU
    93
    Re: Steering box corolla ke30
    Quote Originally Posted by ke30Portugal
    Thanks.
    normally toyota did it like this:
    between the shaft and the chassis you must find
    a nut with a flat screew driver bolt type in the middle
    loose the nut with a long type socket and then tight the bolt just in 90 turns very slowly and comparing using the steering wheel.
    YOU HAVE TO BE CAREFUL WITH THIS,YOU CAN BREAK AND DESTROY THE INTERNAL WITH TIME ,,IF YOU DONT KNOW WHAT YOU ARE DOING!!!!!!!!!!!!!!!!!!!!!
    before you did this ,i recomend to chek the steering linkage and fix all the system if possible
    after that ,,the adjusting should be small and not compromise the internal and the future of the car..
    my price for the diagnosis and the telepatic troubleshooting is
    a "thank you " from you or any other member that found this helpful.
    :tu: :tu: :tu: :tu: :tu: :tu: :tu: :tu: :P
    Oct 2012
    Porto, Portugal
    8
    Thanks for the tip, i will try that.
  1. 1978 KE30 Corolla
    By zsteelman in forum Introduce Yourself
    Last Post: 04-24-2014, 02:30 AM
  2. Toyota Corolla KE30
    By HakosukaGTR in forum Toyota Garage
    Last Post: 04-21-2012, 10:02 AM
  3. WTB: Corolla 1977 (KE30) LHD Dash
    By Augmon in forum Toyota Swap Meet
    Last Post: 08-25-2011, 06:48 PM
  4. Replies: 6
    Last Post: 02-09-2011, 08:11 AM
  5. My-- 1975 Corolla KE30
    By in forum Toyota Garage
    Last Post: 06-17-2009, 04:41 PM
