Results 1 to 6 of 6
Thread: Just picked up my first Corolla (help!)...
    Sep 2012
    Missoula, Montana
    38
    I picked this up this weekend for $250. It's been sitting for a few years, so I hope not to have any big issues with getting it running again. I do have some questions for 3TC guys, I pulled the plugs and there was oil in each one. Am I correct to assume that the spark plug tube seals are bad or is there a bigger issue. I've only ever worked on 20R and 22R. Also, if anyone has the valve cover bolt torque specs, that would be great! Any advice is much appreciated!! Here are some pics. Not pretty, but better than being scrapped! Some of the pics are bad, it was getting dark and the phone flash didn't work too well...
    Sep 2010
    Magna, UT
    689
    Re: Just picked up my first Corolla (help!)...
    Was it the engine side of the plugs or the wire side that was covered in oil?
    If the wire side, the it may just be the rubber that seals the VC tubes to the head.
    Just change all fluids/oils before trying to get her running regularly. The 3T in my car I let sit with oil and open intake ports for 2 years and the damn thing started right up after changing oil, using fresh fuel and quick tune up.
    Sep 2012
    Missoula, Montana
    38
    It was just the wire sidethat had oil. I'll give it a try and see what works...thanks!
    Jul 2012
    439
    Not too shabby for $250. GL on getting it running.
    Sep 2012
    Missoula, Montana
    38
    Got it running yesterday! I had to replace the starter (whose idea was it to put it under the exhaust manifold??) and valve cover gasket (I couldn't believe the crap that was under there!), add some coolant and prime the carb with gas. She fired right up! Won't idle and runs like crap, so I'm sure I have a carb rebuild in the near future. I'm starting to really like the 3TC! I hope to have some good tires and the carb going in the next few weeks (if we don't turn into a deep freeze up here).
    Feb 2007
    Lake Worth, TX
    677
    Good luck with this one. I would love to get my hands on a TE70 Corolla wagon that is a manual. The price is just unreal.
  1. just picked up a 240z
    By atomman in forum Datsun/Nissan Garage
    Last Post: 11-25-2014, 07:46 AM
  2. Picked Her Up!!! shes mine now!!!
    By partyboyjay in forum Mitsubishi Garage
    Last Post: 05-30-2013, 09:39 AM
  3. Just picked up this 76 carry van
    By jamiec in forum Other Marques Garage
    Last Post: 05-08-2013, 09:17 PM
  4. picked up a 83 turbo
    By schassisowner in forum Datsun/Nissan Garage
    Last Post: 08-09-2010, 03:38 AM
  5. Picked up a new (to me) Datsun today...
    By qdseeker in forum Off-Topic
    Last Post: 11-22-2009, 02:03 AM
