Results 1 to 10 of 12
Thread: What engine to choose?
    Oct 2012
    oregon
    160
    Ok so I have a 78 Cressida, budget is only a slight issue but anything is prey much attainable, so what engine to swap?
    Beams 3sge?
    Six speed 220hp cheap 240hp easily attained possibly turbo it later?
    1jz auto? Cheap easy to swap
    2jz auto? More power little more expensive
    2jz 5 speed? Expensive
    1uz?
    2jzge?
    Am I missing another possible idea other then m series that I do not want
    What do you think? I'm not trying to build a monster or anything just a fun car
    Apr 2011
    TX
    283
    Re: What engine to choose?
    Beams 3sge? - how easily attained is this for you? 240hp peak maybe but why would you want to spend all your time up there? break something and getting parts is a relative PITA.
    1jz auto? Cheap easy to swap - assuming you're talking non-VVTi turbo. if leaving the auto trans in is what makes this swap "cheap easy" for you, pass on it.
    2jz auto? - same as above.
    2jz 5 speed? Expensive. thought you said budget isn't an issue though? what transmission are you using? planning on buying a whole set that comes with one or finding your own?
    1uz? - what i'm looking at doing.
    2jzge? - been done so there's parts and knowledge available.
    this seems like a dreaming thread where you want to just shoot the breeze about choices out there. i could arbitrarily pick any motor and make it seem like a horrible/awesome idea for you depending on how i spun the facts. how serious are you about doing this, and why are you doing it? what's your goal for the car?
    5,527
    Quote Originally Posted by Akio
    1UZFE gets my vote. Cheap(ish) and plentiful. Especially if you plan to stay auto.
    Oct 2012
    vegas
    34
    2rz/3rz relatively easy to make 350-450 hp, not exactly cheap though. KO racing has turbo kits for those motors under the "tacoma" section.
    Oct 2012
    oregon
    160
    Mostly I wanted opinions, with vague expressions on my opinions as a forethought. Thanks for the input and a jz swap is easily done, a child could do the wiring there are so many write ups.
    Aug 2010
    Toronto
    61
    Wiring for a 2jzge is simple....for the vvti version....good luck!
    Also, sorting gas tank, fuel lines, pump.. (carb, now efi) is something to consider
    I agree with above poster....each motor has things that are easier about swap, and things that are more challenging...
    1UZ swap I think there are header clearance issues....and the torque in the 1uz will surely grenade the puny stock diff in no time...
    Anyways, once you start a swap, your more specific questions will be easier to answer.
    2jzge seems like the cheapest and best bet.....can also turbo later, (NA-T)
    Jul 2012
    Medford, OR
    16
    What do you have against the M series?
    Oct 2012
    oregon
    160
    Too much money for too little output, 7m just in my past mk3 experiences, usually require a rebuild, I hate the stock intake manifold for fmic, and not much to be had even with the Lexus Afm housing boost wise. Your into it for as much as a jz that will do better anyway, just my opinion/experience
    Aug 2010
    Toronto
    61
    If you decide to go 2jzge, I recently completed this swap in my x3...so I can try and answer any specific questions you may have..
    Jul 2012
    Medford, OR
    16
    Did you buy this car in Roseburg?
    I agree the intake mani design makes plumping a turbo setup a whore...
    But not every 7M needs a rebuild, just ARP head studs and a mhg... which if it was me I would be pulling the head anyway to flow it out... I just like the M series because it's different.
  1. Help me choose my new alloys....
    By 02Anders in forum Resto Tips, Wheels & Other Goodies
    Last Post: 11-21-2013, 06:52 AM
  2. Help me choose wheels!
    By oldisgold in forum Off-Topic
    Last Post: 09-29-2013, 08:01 AM
  3. Ford Courier engine simiar to 808 engine?
    By Dave77 in forum Mazda Garage
    Last Post: 09-19-2011, 08:06 PM
  4. New member, and I need to choose me next ProjectCar? Help me
    By ej20 in forum Datsun/Nissan Garage
    Last Post: 08-24-2008, 12:31 AM
