Results 1 to 4 of 4
Thread: Mazda RX2 Hood Issue
    Jul 2010
    Richland, WA
    53
    All, need a little guidance on how to repair. Though the RX2 hood is welded to the hood frame along the sides and rear, the front is not. The issue I am having is that all of the material Mazda used to adhere the front and middle portions of the hood to the hood frame are no longer adhering, so the hood is starting to move up and down a bit when driving. Does anyone know what material (Adhesive, JB Weld etc....) would work to re-adhere the hood to the hood frame and how to go about this process. I have to assume others have had this problem with their older Mazdas in the past, and hoping for some techniques to repair back to spec.
    Thanks for any help!
    Jan 2012
    Kitchener Ontario Canada
    23
    Re: Mazda RX2 Hood Issue
    Same thing happened to my hood while driving at 90mph, now my hood is bent to shit in the front.
    My cars been off the road for 4 years now so it hasnt been a pressing issue just yet. When I'm ready, I'll take it to a body shop
    Jan 2011
    Perth, Australia
    53
    Common problem.
    I used Sikaflex silicone adhesive (cant remember exactly what type in the Sika range, but we used it at the job I was running assembling caravans - they were held together with it!).
    I pumped it full between frame and skin, then closed the bonnet and taped the top skin hard down with gaffer tape to the front bumper for 24 hrs.
    Feb 2010
    Williston SC
    108
    SEM panel bonding adhesive
  1. Rx2 pitman issue
    By ozzyincali in forum Mazda Garage
    Last Post: 02-19-2014, 10:26 PM
  2. Mx32 issue
    By thatdeafguy in forum Toyota Garage
    Last Post: 07-08-2011, 12:16 AM
  3. MAX POWER DEC. 2009 issue ???
    By toji004 in forum Off-Topic
    Last Post: 01-20-2010, 10:01 PM
  4. still 3t issue
    By hotdoghogie in forum Toyota Garage
    Last Post: 08-28-2009, 04:07 AM
