Results 1 to 3 of 3
Thread: steering slop
    Jul 2010
    Litchfield Park ARIDzona
    382
    steering slop
    i recall a while back we were discussing steering slop reduction by adjusting the steering box, i wanted to see if anyone confirmed the process of adjusting that steering box? I'm not sure if the process would be similar between the Z and the KGC10?
    can someone please chime in and give me some ideas?
    Please and Thank you!
    5,529
    Re: steering slop
    Well, Zs don't have a steering box, they are rack and pinion. :wink:
    The Skyline has a worm gear steering box, and the adjustment procedure is pretty straightforward. On the top of the steering box you'll see a big nut, with what looks like a slot for a screwdriver on the "bolt" that it's on. You simply loosen that nut, use a screwdriver to tighten that "bolt" down a bit, then tighten up the nut. Not unlike adjusting rocker arms on the engine, there needs to be a tiny bit of slack in it or it will increase wear on the steering box.
    This is a steering box from a 1200, but you get the idea...
    Jul 2010
    382
    Re: steering slop
    Thanks! i will give it a go and see how it works out!
  1. RX2 steering parts
    By streetpower in forum Mazda Swap Meet
    Last Post: 07-08-2012, 04:32 AM
  2. What steering wheel is this?
    By Hazwan in forum Datsun/Nissan Garage
    Last Post: 06-02-2012, 05:35 PM
  3. FS:Oem Steering Wheel
    By colt72-jay in forum Toyota Swap Meet
    Last Post: 11-14-2011, 02:01 PM
  4. OBA Steering wheel
    By matsuda9 in forum Resto Tips, Wheels & Other Goodies
    Last Post: 09-27-2010, 05:48 PM
  5. te72 steering
    Last Post: 05-09-2010, 04:13 PM
