Results 1 to 6 of 6
Thread: 67 Toyota corona
    Oct 2012
    1
    67 Toyota corona
    So i have a 1967 Toyota corona 4dr. Im looking to lower the car by cutting the front springs and installing some blocks in the rear.. here my question what size wheel and offset are you guys running on your car for a nice somewhat flush look without the rubbing. I was thinking about running 15x8.25 with a +25 offset with some 195/50/15 tires.. what do you guys think..
    Jul 2007
    okazaki
    136
    Re: 67 Toyota corona
    i think i have seen one corona with the "flush" look but im not sure what size wheels hes running
    i'm sure he's out here in california
    Jul 2007
    okazaki
    136
    Jun 2011
    Brisbane Austruckingfailure
    52
    dude paint your rims red and put some whitewalls on looks awesome!!!
    Oct 2012
    vegas
    34
    If you move the rear bump stops in on the frame you can get another inch of rim under there in the rear, not sure what your ideas are. I am trying to keep the tires in the wheel well while getting as much tire as possible.
    The factory backspacing is about 3.5 om a 5 inch wide rim...
    I will be using 4.5 backspacing on an 8 inch rim...
    so, 1 inch further under the car and 2 inches to fill the wheel well outwards.
    In the front I plan on 4 inch backspacing on a 7 inch rim...should fit nicely...
    Here are the rims I will be using, they build the rims to order so there is no guessing.
    Motegi mr224
    http://www.ultimatewheeltire.com/index. ... mr224.html
    Oct 2012
    Kissimmee Florida
    34
    i got 195/50/15 xxr 501 rims. im almost flush and 2.5 inches from the ground on yust cut springs
  1. Toyota Corona January 1967, Santa Monica, Sheridan Toyota
    By robbieh20 in forum Toyota Garage
    Last Post: 11-14-2012, 07:57 AM
  2. 81 Toyota Starlet & 74 Toyota Corona
    By 732tg in forum Ad / Auction Finds
    Last Post: 04-20-2012, 01:06 AM
  3. Toyota Corona in YJA
    By Yayoi in forum Ad / Auction Finds
    Last Post: 03-26-2012, 03:09 PM
  4. Toyota Corona what lip
    By 3tcRob in forum Toyota Garage
    Last Post: 01-13-2010, 10:17 PM
  5. 78 toyota corona
    By 78toy4dr in forum Toyota Garage
    Last Post: 09-09-2009, 08:48 PM
