Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Adjustable Coilovers?
    May 2010
    Springfield, OR
    100
    So here's the deal, I have a 72 Toyota Corona Deluxe Coupe and I'm wanting to lower the front end but I don't want to cut my springs. I would much rather find some adjustable coilovers or lowering springs to swap in. Now I haven't been able to find anything specifically made for my car or any Toyota that old so I'm wondering if anyone could give me some input on this subject.
    Apr 2010
    AZ
    55
    Re: Adjustable Coilovers?
    I would contact Gabe @ TechnoToyTuning and see if they have any Ground control sleeve kits that will work. If he comes up empty handed, contact Ground control with the diameter of your strut casing and the weight of your car(to figure spring rate) and they will hook you up with what you need
    Im sure any fab. shop in your area can cut you some metal plates for spring perches so you can cut off your existing.
    If there was a Corona out here I get the casings and do it for you
    Sep 2012
    Portland, Oregon
    26
    For a start, check out Pro Auto in eugene. The Corona (at least mine does) uses double A-arm front suspension and leaf spring rear, same as every domestic used for circle track racing since forever.
    Things might have to be machined to fit just right, but Im betting they could at least give you some ideas or point you in the right direction.
    When I lived down there they were on the corner of Roosevelt and Seneca but google maps is showing them somewhere else.... cant be too many sprint car shops down there.
    Mar 2012
    Long Beach
    78
    Not sure if the 72 Corona is the same as the 75 Corona, but I called TTT for an adjustable coilover for my car. He said he didn't have any. I'm planning on cutting some springs and adding better shocks.
    Jul 2011
    Virginia Beach, VA
    17
    Even if the ground control sleeves don't fit perfectly you can make them work. With my ground controls on my AW11 the sleeves didn't fit the front perfectly, so I welded a bead around the top of the strut to make the sleeve snug.
    Apr 2010
    AZ
    55
    I made the same mistake Calus, he has the equivalant to Chevy truck suspension.
    You can measure your spring diameter, use google to figure your wanted spring rate and order from: http://www.speedwaymotors.com/search-coil-springs.html
    Personally I would measure the diameter and hit the junkyard in search for a matching spring from a small truck, then cut to size. Being from a truck they will have a stiffer spring rate and give you that stability we all crave in the corners 8)
    Phil~
    May 2010
    Springfield, OR
    100
    Quote Originally Posted by Jdmturbo
    Phil~
    I like this idea, I will probably do this to get my car lower faster then save up for some QA1's or something to that effect. Do you think some s10 springs would work?
    Jul 2011
    Virginia Beach, VA
    17
    Oh, it doesn't have regular mcphearson style struts then? Most of my experience is from working on my aw11.
    May 2010
    Springfield, OR
    100
    This is what the front suspension looks like on my car:
    Jul 2011
    Virginia Beach, VA
    17
    Quote Originally Posted by The Names Yota, Toyota
    Ohhhh, wow. That... Yeah.
  1. Adjustable height springs on a 1975 Celica.
    By adamyee in forum Toyota Garage
    Last Post: 01-03-2014, 09:10 PM
  2. Rear DIY coilovers
    By Skellington in forum Toyota Garage
    Last Post: 08-17-2012, 03:28 AM
  3. Adjustable Rear springs
    By backspinstarlet in forum Toyota Swap Meet
    Last Post: 07-03-2011, 07:20 PM
  4. Adjustable roof Rack Yakima Style $100 plus shipping
    By FjFairlady in forum Wheels Swap Meet
    Last Post: 01-18-2011, 07:07 PM
  5. NOS TRD 8-way externally adjustable rear shocks
    By spriso in forum Toyota Swap Meet
    Last Post: 07-06-2010, 05:49 PM
