Results 1 to 5 of 5
Thread: w58 shifter question
    Dec 2009
    southern PA
    278
    alright toyota heads i have a question for you all..... i have a w58 out of an sc300 which has the rear facing plate for the shifter assembly. I am installing the 2jz into my first gen cressida and from my research i need a plate off the mid 80s celica supras. i bought the plate, but when i disassembled the one on the trans, the shifter fork is bolted in and it probably wont clear the mid mount plate.
    so how do i remove the shifter fork? it looks sort of pressed in but I'm not 100% sure.
    Oklahoma City
    762
    Re: w58 shifter question
    You need to remove the entire rear cover of the transmission... The part the shifter housing is bolted to. There should be six bolts or so to remove and then the rear half of the transmission will slide backwards. You can then remove the shifter fork. You can then slide your shifter fork on and bolt the transmission back together. It is really easier to start with a W58 out of a MkII supra or same vintage celica if you can find one.
    Dec 2009
    southern PA
    278
    that is not what i wanted to hear
    wonder what one of those forks cost new....
    Apr 2011
    TX
    283
    you can sell the box and find another, or trade with someone for the box you need possibly. this happens more often than you might think and it happens regardless of what car the trans was bought for.
    Dec 2009
    southern PA
    278
    ok so new question...
    the trans clears the tunnel just fine the way it is... but the stock swan style shifter arm hits the interior plastic.... could i just find a short shifter or another style shifter off something else that will work?
    it barely hits but its annoying
  1. WTB-2tc shifter
    By toyorotor in forum Toyota Swap Meet
    Last Post: 02-28-2015, 12:22 AM
  2. WTB 83-85 W58 shifter box & striker arm
    By daveskates in forum Toyota Swap Meet
    Last Post: 02-04-2015, 12:47 AM
  3. wtb MX63/73 shifter or any G or W series shifter
    By spongebob in forum Toyota Swap Meet
    Last Post: 08-12-2012, 11:34 PM
  4. Angled shifter for 1975 Celica GT
    By adamyee in forum Toyota Garage
    Last Post: 04-22-2012, 06:51 AM
  5. short shifter
    By oldskoolte86 in forum Toyota Swap Meet
    Last Post: 01-26-2012, 04:32 AM
