Results 1 to 7 of 7
Thread: 1976 Mazda 929 coupe
    Sep 2012
    Sydney South
    6
    The overhead console has three warning lights for Belt, Fuel & Door which don't seem to come on. I've checked the bulbs - they're fine.
    Does anybody know if there is anything that typically goes wrong with these things?
    Jun 2008
    Tampa FL
    125
    Re: 1976 Mazda 929 coupe
    1, Did you check the fuse?
    2, when you got the car were they like that? (if so check the wiring, you never know whos cut up wires for gauges or some other accessory and then didn't put things back how they were supposed to be)
    Jan 2011
    Auckland, New Zealand
    70
    they were not always connected, it was an option for the lights to be operational or not
    Sep 2012
    Sydney South
    6
    Fuses all look good. Wiring appears untouched.
    This car is my uncle's and he's had it from new. He's almost eighty now and he's hardly used it. It's got 57,000 km on the clock and it's very unmolested so there's no DIY wiring to look out for.
    The cabin lights weren't coming on when I opened the doors either, but I cleaned up the door switches (probably 36yo dried grease or wax) and they're operational again.
    There's a silver relay or timer made by Yushin Seiki up there in the console. Can anybody tell me what it might be?
    Dec 2007
    Australia
    28
    I think the metal box is problem.I am getting mine checked this week.
    Jul 2012
    Adalaide, Australia
    88
    the little metal box (oscillator) is a timer relay for the belt/door lights on the roof console, the fuel low warning is a direct cable link to the fuel sender (which should be 3 pin) and the cable color is Yellow/blue stripe (negative feed) and Green/yellow (12+ feed)
    This should be most of the plugs that should be plugged in (also a 4 pin plug)
    No 388
    Sep 2012
    Sydney South
    6
    That looks like a brilliant diagram. Thanks for that! I haven't for the life of me figured out why there was such a mass of wires up there when there were only five or so incoming wires from the ceiling. Your diagram should solve a few riddles.
    Hopefully I'll have something positive to report back with soon.
  1. 1976 818 Coupé
    By JT1979 in forum Mazda Garage
    Last Post: 08-26-2015, 05:30 PM
  2. 1976 Cedric Coupe
    By R34 in forum Datsun/Nissan Garage
    Last Post: 09-13-2014, 06:24 PM
  3. 1976 Dodge Colt Coupe
    By remarque in forum Ad / Auction Finds
    Last Post: 10-10-2012, 01:41 PM
  4. 1976 mazda 121
    By jimjams in forum Mazda Garage
    Last Post: 08-29-2012, 10:59 AM
  5. 1976 Mazda 929, help with improvements.
    By Dave Nicko in forum Mazda Garage
    Last Post: 11-03-2011, 01:34 AM
