Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: RA45 GT Celica with full on race beams
    Aug 2007
    melbourne
    84
    hi guys here is my ra45 gt with a full on race beams
    last pic is how it is at the moment
    weighs in total with steel cage etc 970 kilos
    car has 310 mm rotors on front with ap4 spot calipers and 28mm thick vented
    on the back are ap 4spots on on 20mm thick vented 280mm
    Apr 2010
    snohomish, washington
    497
    Re: RA45 GT with full on race beams
    By God that engineed is a piece of art...
    Oct 2010
    Lithuania
    83
    Nice car. How much hp are you getting out of that beams?
    Aug 2007
    melbourne
    84
    its making 204 kws at the back wheels at 9200 rpm
    Feb 2010
    Great White North
    144
    Are those cams as big as they look?
    Aug 2007
    melbourne
    84
    yes the inlet is 565 thou and the exhaust cam is 530 thou plus im still using some vvti and in the pics you can see it has 2 stage fuel injection going through my 50mm quad throttles
    all of the inlet and quad throttles i have made same with the 2stage as well
    also make ti retainers for the new valve springs for the steel valves that i use
    the only thing that is not changed on this motor is the block and head
    Dec 2011
    Oxnard Harbor, CA
    64
    What strut/coilover setup are you using?
    Aug 2007
    melbourne
    84
    ra45 strut with a small 65 mm dia spring and using bilstein shocks
    Dec 2011
    Oxnard Harbor, CA
    64
    I guess the better question is what are the rotors sourced from, and did you put any adapters to make the AP calipers fit on the strut?
    Aug 2007
    melbourne
    84
    front rotors are from a seirra cosworth race car ,and are from the rear end 28mm x315 as std ap rotor or harop rotor .
    calipers are radial mount and uses a dog bone with alloy hat.
    the rear of my car comes std with a 7.5 bango and has a alloy bracket bolted to the 3 axle bolts and rear calipers are lug mount,with another alloy hat bolted to the axle
  1. Cam's JDM RA45 Celica
    By Camshaft in forum Toyota Garage
    Last Post: 08-03-2015, 08:37 AM
  2. RARE 79 Celica GT coupe (TA45)(RA45) - GT Headlight pair
    By Supraman in forum Toyota Swap Meet
    Last Post: 08-03-2015, 07:18 AM
  3. RARE 79 Celica GT coupe (TA45)(RA45) - GT Grille (Honeycomb)
    Last Post: 06-29-2015, 12:35 AM
  4. RARE 79 Celica GT coupe (TA45)(RA45) - Square headlight pair
    Last Post: 10-03-2014, 01:59 AM
  5. 1977 Celica GT Coupe FULL PARTOUT
    By fressssssh in forum Toyota Swap Meet
    Last Post: 10-07-2013, 05:48 AM
