Results 1 to 10 of 14
Thread: Where to buy parts for the Toyota Corona mk2 (1973) ??
    Sep 2012
    Norway
    8
    As topic says:
    Thinking of window gaskets
    Complete kit of bushings.
    Thanks.
    Regards...
    Jul 2012
    Orange County, CA
    116
    Re: Where to buy parts for the Toyota Corona mk2 (1973) ??
    For the window weather strips talk to "theunstated" in this forum he can help you out with those.
    For all the suspension components, I can help you out with those. I have a complete list of every part number for the 73 rona mk2. Only bad part is, I have no idea where I left it. But check out the company "rare parts" they make every suspension component for the mk2.
    If you go to an o'reilly auto parts, they have a way of getting you all the part numbers you need and ordering them. I used to work there, that's how i got all my part number for my 73 mk2.
    Hope this help!
    Sep 2012
    Norway
    8
    Thank you.
    Please feel free to tell me more if you should remember....
    Regards..
    Jul 2012
    Orange County, CA
    116
    Just found the sheet...
    Sway bar bushings #16117
    Idler arm #20281
    Tie rod outer #26217
    Tie rod inner #26227
    Tie rod adjustment sleeve #26208
    Ball joint upper #10194
    Ball joint lower #10202
    Control arm bushings:
    Front upper #15156
    Front lower #15218
    Rear upper #15285
    Rear lower #15286
    These are all made by the company "rare parts," since moog is a more common company, you might be able to interchange these part numbers off google.
    Good luck! Hope this helps.
    Sep 2012
    Norway
    8
    Thanks again. It sure helps!
    Sep 2012
    Norway
    8
    What about new body parts?
    Do you know the thickness of the "body metal"? 0.6mm?
    Jul 2012
    Orange County, CA
    116
    I have no idea on that. Body parts are so hard to come by for 73. Anything new would be pretty much non-existant. Everything would be pretty much used.
    Is yours coupe, sedan, or wagon?
    Sep 2012
    Norway
    8
    Jul 2012
    Orange County, CA
    116
    Very nice, everything looks in order with the body, how come you're looking for new parts?
    Sep 2012
    Norway
    8
    The front panels is not aligned with the door... The pictures are lying... Big time... :S
    Panels have sunken down and are interfering with the door... Specialy on drivers side...
    The bushings list that you wrote down... Is it for the entire car?
  1. I lost my 1973 Toyota Corona ignition key.
    By robroymcgregor in forum Toyota Garage
    Last Post: 12-11-2014, 07:02 PM
  2. 1973 toyota corona 2dr hardtop
    By drift in forum Toyota Garage
    Last Post: 09-30-2013, 02:31 AM
  3. WTB MX12, MX13 1973 Corona mark II parts..
    By njccmd2002 in forum Toyota Swap Meet
    Last Post: 05-02-2013, 07:47 AM
  4. 1973 toyota corona deluxe sedan rt85 parts for sale
    By rt85corona in forum Toyota Swap Meet
    Last Post: 08-28-2012, 06:43 PM
  5. 1973 Toyota Corona Coupe - PICS
    By in forum Toyota Garage
    Last Post: 07-07-2009, 01:58 AM
