Results 1 to 4 of 4
Thread: Looking at buy a 83 Cressida
    Jun 2008
    ohio us
    102
    Im currently looking at buy a 83 Cressida the body is pretty clean it's got around 190k on it I've never had a Cressida before so I'm unknown to there motors is there anything to look out for at buy a car at the miles it has ? Any info will help thanks!
    Dec 2009
    southern PA
    278
    Re: Looking at buy a 83 Cressida
    look for rust.... the 5m is probably tired but not definitely dead...they seem to be more stout than the 7ms in the later cars
    Sep 2009
    Arizona
    35
    It all depends on what you are going to do with this car. If this is going to be an every day driver, you'll have a handful of things you'll want to check and replace.
    The 5M is pretty stout; mine lasted 240k miles before it blew the headgasket. I've heard other people have had weird issues with the EFI system/wiring.
    Check/replace the rear differential mount, rear crossmember mounts (Super Pro sells a nice set), the blower motor has been a common thing to go bad, the rear seal (driveshaft seal) on the trans tends to leak after a while, it's a $5 seal that is worth replacing.
    Apr 2011
    TX
    283
    pics? i have a couple x6's in yards local to me if you end up wanting parts.
  1. Cressy Cressida MX62 Cressida Wagon
    By ram9cc in forum Toyota Garage
    Last Post: 05-18-2015, 08:27 PM
  2. '79 Cressida
    By TSiSS350 in forum Toyota Garage
    Last Post: 10-06-2014, 02:17 PM
  3. My Cressida
    By Hondafiend in forum Toyota Garage
    Last Post: 06-03-2013, 03:35 PM
  4. need 78 cressida help.
    By okibum03 in forum Toyota Garage
    Last Post: 05-06-2011, 05:14 AM
  5. Not another cressida!!!
    By OkieRA29 in forum Toyota Garage
    Last Post: 10-12-2010, 09:39 PM
