Results 1 to 6 of 6
Thread: 83 Datsun Maxima/910 wheel offset
    Sep 2009
    Nixa MO
    4
    My friend Ed introduced me to this site today.
    I found some really nice cars on here!
    Done some searching already and had no luck.
    Wanting to know the offset on factory wheels for my 83 Maxima/910.
    Found a number sequence on the front of the wheel that says possibly
    +35? Looking at putting another set of wheels on that are 16x7 +15 fronts
    and 16x8 zero offset rears. I'm wanting the wheels to stick out past the
    factory sheetmetal and run fender flares.
    Here is a pic of my car.
    Any help would help.
    Thanks,
    Brian
    Sep 2009
    Nixa MO
    4
    Here's a pic of the car with the wheels I'm asking about.
    Thanks,
    Brian
    5,527
    Those wheels are definitely in the +25 to +35 range.
    To get them out past the fenders, we need to know your target wheel width for a recommendation on offset. :tu:
    Sep 2009
    Nixa MO
    4
    Thanks for the response........the +35 if what I was thinking also.
    Thank you,
    Brian
    Feb 2008
    Yes, it's a state.
    107
    You want the rear rim to stick out of the existing fender right?
    For your application, a 16x8 +0 offset rim will probably be on the same line as your fender or just slightly less. It wouldn't stick out. You would have to have a rim with a - (negative) offset in order for it to stick out of your fender. What is the original Maxima rim size?
    Sep 2009
    Nixa MO
    4
    Yes, that is correct and the factory wheel size is 14x5.5.
    Brian
  1. DR30 Wheel size and offset help
    By Davboy in forum Datsun/Nissan Garage
    Last Post: 07-12-2012, 07:17 PM
  2. ID this wheel offset plz...
    By ericbauer in forum Datsun/Nissan Garage
    Last Post: 07-29-2011, 02:41 AM
  3. RA23 Wheel Offset?
    By rxfury in forum Toyota Garage
    Last Post: 07-28-2011, 04:07 PM
  4. One owner 1982 Datsun Diesel Maxima Sedan w/66k miles!
    By ww in forum Datsun/Nissan Garage
    Last Post: 12-31-2010, 01:30 AM
  5. '83 Datsun Maxima
    By 810 Max in forum Datsun/Nissan Garage
    Last Post: 07-30-2010, 02:32 AM
