Results 1 to 10 of 15
Thread: Lowering opinions?
    Jul 2009
    roseland, california
    18
    Lowering opinions?
    1970 corona mark II. how low to go?
    Jul 2009
    18
    thanks for the help.
    I got some western wheels, model vector. you know, the "turbines". the previous owner had them chrome plated. they are amazing, i think i scored. 13x7 rear, and 13x5.5 front. almost brand new yoko's
    Feb 2008
    Yes, it's a state.
    107
    Since you already have the wheels, did you try to put it on?
    If the rim extends out beyond the fender then you can't really fit the tires into the stock fender unless you change the camber to an extreme negative amount which is not recommended.
    Jul 2009
    18
    western wheels, cyclone I, 13x7. lowering opinions?
    fitted the wheels, fronts are perfect, rears extend maybe a half inch. any opinions on how low to go?, (i know terrible picture, my wide angle lens distorts everything.) I'll send a better pic after my camera charges.
    Jun 2008
    Torrance CA
    277
    this is how low mine is. I dont like wheels that stick out. i like a nice old school Japan style look.
    Jun 2008
    Torrance CA
    277
    oh and this is the front end of my 71 RT72
    Apr 2009
    DFW TX
    188
    Re: thanks for the help.
    Quote Originally Posted by mark corona II
    i have a set of the same wheels, with the orignal finish but mine are 14 x 7 +25 offset, i just need tires for em' , those look gooooodd :tu:
    Feb 2009
    Hoquiam, WA
    712
    What size are the tires? Maybe look into 185 60 13 (I know federal makes them) and then drop the car 3-4". Looks like you'd need to roll the fenders a bit, and if you are live axle you'd want to look into your options for an adjustable panhard or get your's shortened.
    My opinion is pretty biased though, I like my cars scraping .
    Nov 2007
    Limerick Ireland
    53
    As low as is physically possible,
    Feb 2007
    Napa Ca
    209
    The question becomes do you want it to handle well, or look low and handle like crap? I say do some homework and lower it till the roll center and roll axis are correct, then it will both look good and handle great.
    If you over lower a car and the roll center goes below ground the only way make it sort of work is run stupid high spring rates (just ask any Alfa Romeo GTV or Spider owner who has lowered their car at all from stock. 1300 # spring rates for the front end are not uncommon for a street car that never will see track time.) You could also run drop spindles but those have there issues as well. Simply lowering the car is easy to do, doing right is another story. In my book, if I'm going to do something I might as well get it right. That said, my Alfa is lowered from stock and it does run 1300 lb springs in the front. There is no easy way to fix the roll center and other geometry issues. I just have to be aware of any dips in the road or places that my oil pan will scrape hard. I have knocked the oil drain plug loose on more than one occasion. (I quit driving that road in that car.)
    Just a thought,
    Will
  1. Motor opinions
    By UtahSleeper in forum Toyota Garage
    Last Post: 08-29-2012, 11:32 PM
  2. looking into buying this celica! opinions ?
    By bochorongo in forum Toyota Garage
    Last Post: 03-24-2011, 03:37 AM
  3. i'm stump on a trade offer, advice? opinions? criticisms?
    By pdx96 in forum General Discussion, JNC News & FAQ
    Last Post: 12-30-2010, 05:49 AM
  4. Wheel sizing opinions/help needed - Paging Dsalni
    By camerashy in forum Datsun/Nissan Garage
    Last Post: 10-17-2010, 07:03 PM
  5. Corona wheels opinions?
    By chillywilly263 in forum Toyota Garage
    Last Post: 08-04-2010, 06:24 PM
